![[GRADE S] IBASSO DX240 Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Black](https://www.audiophonics.fr/53668-thumb_default/-grade-s-ibasso-dx240-digital-audio-player-dap-dac-es9038po-balanced-bluetooth-50-wifi-32bit-768khz-dsd512-mqa-black.jpg)
 ![[GRADE A] AUNE S9C PRO DAC 2x ES9068AS Discreet Headphone Amplifier 5W Bluetooth 32bit 768kHz DSD512 MQA Back](https://www.audiophonics.fr/64487-thumb_default/aune-s9c-pro-dac-2x-es9068as-discreet-headphone-amplifier-5w-bluetooth-32bit-768khz-dsd512-mqa-back.jpg)
 Power Connector DIN 4 Pins for NAS Synology (Unit)
This DIN 4 pins connector will allow you to create your own power cables, especially for Synology's NAS brand connectors. The connector accepts cables up to 6.4mm in diameter.
This connector has 7 parts to assemble. This step-by-step guide will help you complete the assembly. Be sure to follow the order of this guide and the direction of the parts, as shown in the photo below.
Attention, once the connector is assembled, it becomes very difficult or impossible to undo it.
The connector is now assembled. Of course it is not detailed here the assembly of your cable in the connector, which is to be provided before the assembly of the connector.
After step 4 of this guide, you should get this set of parts:
| Specifications | |
| Connector | DIN 4 pins |
| Max cable diameter | 6.4mm |
| Total connector dimensions | 45 x 13.8mm |
| Housing material | ABS + PBT |
| Color | Black |
| Quantity | Sold by unit (1) |
| Max cable diameter (mm) | 6.4 |
| Mounting type | To weld |
| Connectic | Male |
| Contacts number | 4 |
| Max panel thickness (mm) | N/A |
| Connector | DIN |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | None |
| Average votes  5.0 / 5  1 reviews | Why write products reviews ?  You can share your feelings about products and help other people by sharing your experience |
