DAC Module AKM AK4495SEQ + AK4118 32bit / 384kHz
DIY DAC AKM AK4495 + AK4118 Kit 32bit/384kHz DSD XMOS
3.5 / 5
Reference : 11126
89,00 €tax incl.
74,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
This DAC module with source selector is ready to play any type of High Definition files.
It integrates the new chip AKM AK4495SEQ32bit 384khz associated with a receiver coaxial / Optical Toslink SPDIF AK4118.
Moreover, thisDAC AK4495SEQhas an input of type I2S compatible with pin pine with this interface XMOS U208 USB.
This DAC module is therefore able to convert a digital signal with a sampling frequency of 32 to 384kHz, in 16, 24 or 32bit.
This new converter includes a blue display and a source selector to select one of the 2 digital inputs available.
In addition, the AOP provided is a LM49860 on DIP8 interchangeable support.
Features:
  • Blue display 16x2 (71x29mm).
  • Inputs: 1x Optical, 1x Coaxial and 1x I2S.
  • Converter AKM AK4495SEQ.
  • SPDIF Receiver AKM AK4118.
  • Decoding up to 32bit 384kHz by AK4495 on I2S connector.
  • Decoding up to 24bit 192kHz by AK4118 (Optical and Coaxial).
  • Signal Noise Ratio: 123 dB.
  • AOP high fidelity: LME49860 removable on supports DIP8.
  • Supply via a single transformer:30VA 2x 15 / 16V + 2x 9V.
  • Delivered with its screen + selection button
Dimensions and weight:
  • Dimensions of the main board: 132x118x27mm.
  • Mounting hole distance from the main PCB: 108x92mm.
  • Fixing hole distance from display: 78x32mm.
Pinout I2S / USB
InputI2S
Channel2 (Stereo)
2 reviews
Tutto bene ma...
Perche l'AOP fornito è un JRC 5532 e non un LM49860...
This review has been posted for DAC Module AKM AK4495SEQ + AK4118 32bit / 384kHz
R ROELS
Excellent convertisseur, la base est très saine, musical, respect des tombes, dynamique, en entrée usb comme entrée spdif
Pour en avoir fait acheter une bonne douzaine pour les amis et proches, c est du bonheur, rien a envier a des convertisseurs de 1000€ a 1500€ ( croyez moi mon expérience, je suis ingénieur du son 35 ans au service de la musique ), après une petite modification sur la sortie analogique c est un pur bonheur, je vous conseil le même dac tout monté en vente sur ce site
