Internal width
mm
mm
Internal depth
Internal height
Material
Diameter (mm)
Height
mm
mm
Button type
Number of positions
Color
DIY enclosures and cases
Jean-louis L.
Jean Michel P.
Hervé R.
Pas si bien que ça !
Want to start a DIY audio project? This category is for you. You will find all our cases, in which to install your components in order to protect them and of course, to create a performing and aesthetic product.
  • Aluminium Boxes / Cases
    Discover our range of Aluminium cases and chassis for the design of your DIY audio devices.
  • Slimline chassis
    Slimline chassis
    Here you can find all HiFI 2000 enclosures from the Slimline range, which is characterized by thin enclosures that can be installed in racks.
  • ECO Chassis
    ECO Chassis
    The HiFi 2000 ECO range includes a number of enclosures characterized by a high quality of design, combined with a contained price.
  • Galaxy Chassis
    Galaxy Chassis
    Discover the Galaxy range from HiFi 2000. Models with a very nice design quality, particularly robust and ideal for the integration of DIY audio projects.
  • 19" Chassis
    19" Chassis
  • 19" Chassis with Heatsink
  • Mini Dissipante Cases
  • Other Chassis
    Other Chassis
  • Spare Parts
    Spare Parts
    Spare Parts
  • Heatsink
    Heatsink
  • Switches
    Switches
    Switches and buttons are divided into 2 categories:
    • Monostable switch (pushbutton or fugitive button): Returns immediately to its initial position when pressed. It has only one possible position.
    • Bistable switch: When pressed, the switch is engaged and changes position. Several positions are therefore possible, unlike a monostable switch.
  • Various accessories
    Various accessories
