SPDIF Digital Interface Board for Rasberry Pi 24bit 192kHz
The HiFiBerry Digi+ I/O is a digital SPDIF interface for Raspberry Pi. It allows a Raspberry Pi to have a coaxial and optical SPDIF output via its 40 pin GPIO input. It uses an I2S connection to recover the audio signal without the need for additional USB conversion. The module supports sample rates up to PCM 24bit 192kHz.
It also has 2 inputs, Coaxial and Optical, for even more functions.
The Raspberry Pi is sold separately.
Product type | Digital interface |
Input | GPIO 40 pins 1x Coaxial 1x Optical Ttoslink |
Outputs | 1x Coaxial 1x Optical Toslink |
Supported sampling rates | PCM up to 24bit 192kHz |
Dimensions | 55 x 65 x 15mm |
Weight | 20g |
Input | SPDIF |
Input | GPIO |
Input | Optical |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Max sampling rate | 192kHz |
Interface chip | WM8804 |
