DSPEAKER ANTI-MODE 2.0 DUAL CORE Stereo Acoustic Room Correction DSP
The DSPeaker Anti-Mode 2.0 Dual Core is an award-winning speaker optimization system capable of improving the acoustic performance of any full-range stereo audio system. It is based on the company's Anti-Mode 2.0 algorithm. The DSP measures the acoustics of the room and automatically corrects for defects in the room's acoustics to provide improved sound reproduction.
By buying this product you get 89 loyalty points
Reference : 16993
899,00 €tax incl.
749,17 € tax excl.
Shipping date: 16-07-2025.
DSP Correction Acoustique Stéréo
DSPeaker Anti-Mode 2.0 Dual Core DSP Correction Acoustique Stéréo
The interaction between the speakers and the listening room is usually the main factor limiting the performance of any high-end audio system. Each listening space introduces errors that can be on the order of ten decibels or more. These errors are generally most pronounced in the low frequency and low midrange regions, where conventional acoustic processing loses its effectiveness.
1IR Receiver
2TFT Screen
3Microphone input
4Balanced XLR input
5Balanced XLR output
6Single-ended RCA input
7Single-ended RCA output
812VDC Power connector
9Mini USB input
10Optical Toslink input
11Optical Toslink output
12DataLink Connector
Product typeRoom correction DSP
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
1x Optical Toslink
1x Mini USB
1x Jack 3.5mm microphone input
Outputs1x Balanced stereo XLR
1x Optical Toslink
Functions / FiltersFIR / IIR
Filter curve
Linear Phase Tilt
Parametric EQs
Adjustable infrasonic
Adjustable low-pass or high-pass
Dynamic range> 108dB
Volume control steps0.5dB
Input senstivityXLR : 3.9/7.9Vrms
RCA : 2.5/5.0Vrms
Output voltageXLR : 14.4Vrms max
RCA : 7.2Vrms max
ADC6.144MHz oversampling dual per channel
DAC6.144MHz oversampling dual per channel, local clocking, buffering
Supply voltage12VDC
Dimensions (L*P*H)236*153*55mm
Package1* DSPeaker Anti-Mode 2.0 Dual Core
1* Measurement microphone
1* Remote control
1* Power supply
InputXLR
OutputOptical Toslink
Max sampling rateNC
The DSPeaker Anti-Mode 2.0 Dual Core is an award-winning speaker optimization system capable of improving the acoustic performance of any...
