DSPEAKER ANTI-MODE 8033 CINEMA Automatic Subwoofer Bass Correction DSP
10%
Get rid of the standing waves that mask the bass in your home theater audio system with the DSPeaker Anti-Mode 8033 Cinema. Automatically calibrate your system at the touch of a button with this powerful and easy-to-use DSP.
Reduced price!
Reference : 16992
Limited time offer:
349,00 €tax incl.
-10%
314,10 €tax incl.
261,75 € tax excl.
Last items in stock !
Shipping date: 16-07-2025.
DSPeaker Anti-Mode 8033 Cinema DSP Correction Basses Fréquences Subwoofer
A typical listening room resonates in the low frequencies. For this reason, even the best subwoofer can't reveal its full potential without proper acoustic treatment or correction. Golden Ear award-winning Anti-Mode™ technology eliminates resonance by equalizing responses with precise digital filter structures and anti-phase technology. As a result, the subwoofer can truly express itself all the way to its crossover frequency. In addition, the transient response is also improved for faster, punchier and more controlled bass.
The Anti-Mode 8033 Cinema is very easy to use. The calibration process is fully automatic. It generates frequency sweeps to the desired calibration point (or multiple points) and measures the combined transfer function of the subwoofer/room assembly.
1Microphone input
2Lift button
3Bypass button
4ON/OFF LEF
5Bypass LED
6Lift25 LED
7Lift35 LED
8Power supply input
9RCA line output
10RCA Line input
Product typeBass correction DSP
Inputs1x Mono RCA line input
1x Jack 3.5mm microphone input
Output1x Mono RCA line output
Correction range16Hz-160Hz
Accuracy1/82oct
Custom filters28
Correction method40bit Arithmetic
Frequency response5Hz-160Hz
Dynamic range> 90dB
Input sensitivity1.75Vrms
Latency2.7ms
Supply voltage9VAC or 12VDC
Dimensions (L*P*H)126*80*28mm
Weight230g
Package1* DSPeaker Anti-Mode 8033 Cinema
1* Measurement microphone
1* Power supply
Max sampling rateNC
Get rid of the standing waves that mask the bass in your home theater audio system with the DSPeaker Anti-Mode 8033 Cinema. Automatically calibrate...
