Very good and easy to use digital eq/filter. Very good sound.
To bad it´s discontinued from the manufacturer.
Easy business and quick delivery to Sweden from Audiophonics. //Space1999
IIR digital filter / DAC 24bit 96Khz
The MiniDSP 2X4HD interface is a processor for digital filtering. It uses a 24 bit / 48kHzDAC (digital / analog converter) & asynchronous USB Audio Class 2.0 input. Like many other miniDSP devices, 2x4 provides powerful, accessible tools to implement a digital filter (IIR Butterworth / Linkwitz Riley 6 to 48dB) and a parametric equalizer. It will suit audiophiles who want to set an effective correction on a pair of stereo speaker. The device can also be used to manage multiple subwoofers in a home theater setup.
In addition to its digital input, the 2x4 in miniDSP has a stereo analog input on phoenix connector for connecting another Hi-Fi device with analog output. Such as a turntable via a RIAA box, or any other analog source. It is a great accessory to centralize the whole installation on a single pair of speakers, while enjoying a correction / filter that extends to the entire chain.
The 2x4 features a 28 / 56bit floating-point Analog Devices audio processor. The latter allows digital audio calculations as well as control via the USB interface in real time.
The MiniDSP 2X4 provides a complete solution with USB & analog inputs, filtering and parametric EQ.
| Specifications | |
| DSP engine | 28 / 56bit |
| DAC / ADC | 24 bit 48kHz |
| Connectivity Standard | balanced |
| analog input | balanced, switchable with jumper 0.9Vrms and 2Vrms |
| analog outputs | balanced: Max 0.9Vrms changed to 2V (see manual) |
| Digital Input / Output | Micro-USB (I2S interface) |
| capacitors | Nichicon |
| Volume Control | potentiometer (inside the housing) |
| Pilot | USB Plug & Play with real-time software setup |
| Dimensions | 75 x 75 mm |
| Power supply | Jack DC 5.5 / 2.1 |
| Package Contents | |
| Interface miniDSP 2x4HD balanced | x1 |
| 12V adapter plug UK / EU / US / AU | x1 |
| shielded USB cable | x1 |
| Code to download the plug-in 2 x 4 | x1 |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Lennart L.
Laurent l.
Vincent G.
