The MiniDSP MCH Streamer Box is an asynchronous multi-channel USB to Toslink/ADAT interface. It incorporates a high-quality XMOS Xcore 200 USB interface chip to ensure excellent sound reproduction. The USB 2.0 standard gives this interface high performance for multichannel playback and recording. Using one of the supplied MiniDSP firmware packages, the MHC Streamer Box is able to switch between ADAT and Toslink signals. In addition, this device works plug-and-play thanks to native Mac OS and Linux (Alsa) drivers. For Windows, however, an ASIO/WDM driver is required.
Specifications | ||
Product type | USB to ADAT / Optical Toslink interface | |
USB interface chip | XMOS Xcore 200 | |
Compatibility | Windows Mac Linux 2.0 Android iOS (with camera kit) | |
Sampling rates supported on optical input/output | Toslink: stereo support up to 44.1/48/88.2/96/176.4/192 kHz ADAT: 8-channel ADAT mode at 48/44.1 kHz and 4-channel ADAT mode at 96 kHz |
General | ||
Alimentation | Via USB | |
Dimensions | 24 x 64 x 67mm | |
Package | 1x MCH Streamer Box 1x USB cable 1m 2x Optical Toslink cable |
Input | Optical |
Input | USB |
Output | Optical Toslink |
Max sampling rate | 44.1kHz |
Max sampling rate | 192kHz |
Max sampling rate | 48kHz |
Max sampling rate | 96kHz |
Color | Silver |
