DSP Board for HiFiBerry AMP100 / DAC2 HD / DAC2 Pro / Digi2 Pro
This HiFiBerry Add-On DSP card provides digital signal processing capability to the following modules:
The module intercepts the digital stream from the Raspberry Pi to make changes to it, before passing it on to the module it is associated with. It allows access to functions such as IIR and FIR filters, volume control, compressors, equalization, acoustic correction and much more. To access these functions, it is necessary to use the SigmaStudio software.
In case you do not want to do this configuration, it is also possible to use the predefined DSP profiles provided by HiFiBerry, using DSP Toolkit.
DSP Toolkit Download and InstalllationThe module is directly supported under HiFiBerry OS. With other distributions, it will be necessary to install the DSP Toolkit to program the DSP.
Product type | DSP Board |
Compatibility | AMP 100 / DAC2 HD / DAC2 Pro / Digi2 Pro |
