Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Color
Electronic components
Walter V.
Great product!
Joli mais non..
NAEL C.
Marvelous !
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 4271
    In Stock
    Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost reasons, as they are generally much more compact than their film counterparts. In particular, they are widely used in crossover filters.
    5,00 € 4,17 €Ex.
    In Stock
  • Ref : 4263
    In Stock
    1,80 € 1,50 €Ex.
    In Stock
  • Ref : 4264
    In Stock
    2,20 € 1,83 €Ex.
    In Stock
  • Ref : 4265
    In Stock
    2,30 € 1,92 €Ex.
    In Stock
  • Ref : 4266
    In Stock
    2,90 € 2,42 €Ex.
    In Stock
  • Ref : 4267
    In Stock
    3,90 € 3,25 €Ex.
    In Stock
  • Ref : 4268
    In Stock
    3,90 € 3,25 €Ex.
    In Stock
  • Ref : 4269
    In Stock
    4,50 € 3,75 €Ex.
    In Stock
  • Ref : 4270
    In Stock
    4,90 € 4,08 €Ex.
    In Stock
  • Ref : 4299
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 4294
    In Stock
    4,50 € 3,75 €Ex.
    In Stock
  • Ref : 4302
    In Stock
    3,90 € 3,25 €Ex.
    In Stock
  • Ref : 4295
    In Stock
    6,20 € 5,17 €Ex.
    In Stock
  • Ref : 4296
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 4292
    In Stock
    7,00 € 5,83 €Ex.
    In Stock
  • Ref : 4298
    In Stock
    8,50 € 7,08 €Ex.
    In Stock
  • Ref : 16230
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 5675
    In Stock
    The F-Series combines small size and low price, making it an excellent value for money for filtering woofers, or any other application requiring high inductance and/or low resistance in a small volume.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 5659
    In Stock
    7,50 € 6,25 €Ex.
    In Stock
  • Ref : 5663
    In Stock
    7,50 € 6,25 €Ex.
    In Stock
  • Ref : 5664
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 5667
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 5668
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 5670
    In Stock
    10,50 € 8,75 €Ex.
    In Stock
  • Ref : 5671
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 5669
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 5673
    8,80 € 7,33 €Ex.
    In Stock
  • Ref : 5674
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 5672
    In Stock
    8,30 € 6,92 €Ex.
    In Stock
  • Ref : 4233
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low internal impedance and zero...
    5,90 € 4,92 €Ex.
    In Stock
  • Ref : 4235
    In Stock
    4,90 € 4,08 €Ex.
    In Stock
  • Ref : 3415
    In Stock
    5,90 € 4,92 €Ex.
    In Stock
  • Ref : 4232
    In Stock
    4,90 € 4,08 €Ex.
    In Stock
  • Ref : 4234
    In Stock
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 4236
    In Stock
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 4237
    In Stock
    5,90 € 4,92 €Ex.
    In Stock
  • Ref : 4238
    In Stock
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 4239
    In Stock
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 4240
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
