Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
jevgenijs S.
Simply great!
My speakers never sounded this good! A very clear and open sound without being fatigue! The tone controls are very effective!
Reinhardt S.
VIABLUE EPC-4 Silver Balanced Interconnect Cable Ø3.9mm
sehr gute Qualität,sehr empfehlenswert
Reinhardt S.
NEUTRIK NC4MX-B 4 Gold Plated
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 1647
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low internal impedance and zero...
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 1649
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 1650
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 1651
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 1652
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 1653
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 1654
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 1655
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 1656
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 1658
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 1659
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 1660
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 1669
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 1670
    In Stock
    65,50 € 54,58 €Ex.
    In Stock
  • Ref : 1657
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 1661
    41,90 € 34,92 €Ex.
    In Stock
  • Ref : 1662
    In Stock
    45,90 € 38,25 €Ex.
    In Stock
  • Ref : 4574
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 1663
    In Stock
    51,90 € 43,25 €Ex.
    In Stock
  • Ref : 1664
    In Stock
    58,90 € 49,08 €Ex.
    In Stock
  • Ref : 4575
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 1665
    In Stock
    66,90 € 55,75 €Ex.
    In Stock
  • Ref : 1666
    74,90 € 62,42 €Ex.
    In Stock
  • Ref : 1667
    82,90 € 69,08 €Ex.
    In Stock
  • Ref : 1668
    In Stock
    91,90 € 76,58 €Ex.
    In Stock
  • Ref : 3356
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 3357
    In Stock
    14,70 € 12,25 €Ex.
    In Stock
  • Ref : 3354
    In Stock
    11,00 € 9,17 €Ex.
    In Stock
  • Ref : 3358
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 3359
    In Stock
    18,50 € 15,42 €Ex.
    In Stock
  • 61,90 € 51,58 €Ex.
    In Stock
  • 69,90 € 58,25 €Ex.
    In Stock
  • Ref : 3371
    In Stock
    In Stock
  • Ref : 3372
    In Stock
    115,00 € 95,83 €Ex.
    In Stock
  • Ref : 3374
    In Stock
    175,00 € 145,83 €Ex.
    In Stock
  • Ref : 3375
    In Stock
    125,00 € 104,17 €Ex.
    In Stock
  • Ref : 3377
    In Stock
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 3378
    In Stock
    97,50 € 81,25 €Ex.
    In Stock
  • Ref : 2391
    In Stock
    30,90 € 25,75 €Ex.
    In Stock
  • Ref : 2390
    In Stock
    28,90 € 24,08 €Ex.
    In Stock
