If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its Premier SE Ethernet, Pangea offers RJ45 cables using top-of-the-range materials and a careful design to ensure excellent performance.
The Pangea Premier SE Ethernet integrates 26AWG (0.129mm²) copper cardas conductors with silver plating to ensure maximum conductivity. Cardas Copper, developed by George Cardas, has an exceptional quality. The latter is mined in Arizona and then sent to a New England factory where it is very slowly transformed into conductors via a long process to maximize its purity. The conductors are then delivered to a second factory in order to apply the Silver plating.
Always with performance in mind, the cable is covered with a PE sheath. In addition, each conductor is individually shielded, a requirement for Cat7 Ethernet standard and triple shielding is then added to minimize the negative impact of EMI / RFI interference.
| Specifications | |
| Product type | RJ45 Ethernet Cable |
| Connectors | 2x RJ45 |
| Length | 2m |
| Ethernet category | Cat7 |
| Conductors material | Cardas Copper |
| Conductors plating | Silver |
| Conductors section | 0.129mm² (26AWG) |
| Insulation | PE |
| Shielding | Individual shielding of each conductor + triple shielding |
| Connectors plating | Gold |
| General | |
| Cable color | Black and Gray |
| Package | 1x Pangea Premier SE RJ45 Ethernet Cable |
| Length (m) | 2.0 |
| Shielding | Yes |
| Section (mm²) | 0.129 |
| Connector | RJ45 |
| Conductors Plating (Cable) | Silver |
