VIBORG LAN8 Ethernet RJ45 Cable Cat8 Pure Silver Cryo Treatment 1m
The Viborg LAN8 RJ45 Ethernet cable is a high-end Ethernet cable with an exceptional design. This cable features 99.998% pure solid silver conductors. The VIBORG LAN8 features a 2000MHz transmission speed and 40Gbps fiber synchronization.
By buying this product you get 39 loyalty points
Reference : 19022
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 13-05-2026.
VIBORG LAN8 cable picture
The Viborg LAN8 RJ45 Ethernet cable is a high-end Ethernet cable with an exceptional design. This cable features 99.998% pure solid silver conductors. It also features double shielding with metallic foil and silver-plated copper braid, as well as PTFE insulation. It has been cryogenically treated at -196°C. The cable also features CAT8 network connectors with gold-plated contacts on both sides. The VIBORG LAN8 features a maximum frequency of 2000MHz and a bandwidth of up to 40Gbps.
Overview of VIBORG LAN8 cable structure
Viborg LAN8 cable structure diagram
1Pure solid silver
2PTFE insulation (Teflon)
3Metal foil shielding
4Silver-plated copper braid shielding
5PE sheath
6Braided nylon + PPS
Product typeRJ45 ethernet cable
Connectors2x RJ45
Conductors materialPure solid silver (99.998%)
InsulationPTFE
ShieldingMetal foil + silver-plated copper braid
External sheathPE (Polyéthylène)
Covering sheathNylon + PPS
Length1m
Package1x Viborg LAN8 RJ45 ethernet cable
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorRJ45
Conductors material (Cable)Silver
The Viborg LAN8 RJ45 Ethernet cable is a high-end Ethernet cable with an exceptional design. This cable features 99.998% pure solid silver...
