Impedance (Ω)
Speaker Type
Diaphragm type
Loudspeaker diameter (mm)
9 - 203
Efficiency / Sensitivity (dB)
85 - 102
Xmax (mm)
1 - 4
Lowest frequency (Hz)
10 - 310
Highest frequency (Hz)
0 - 56000
Speaker Power (W RMS)
0 W - 305 W
Patrick K.
Sonic Master
This cable is sooooo good that i was shocked. I did not expect this level of warm neutral detailed rich, open and airy sound...
Pierre-Marin L.
Je confirme tous les commentaires élogieux sur ce câble...
Patricio C.
Dale una oportunidad de escucha en tu sistema... y juzgalo tu mismo.
Más vale tener potencia bajo el pedal y no necesitarla que al revés.... y vaya si se nota ir sobrado de potencia. Antes usaba...
Exciters
This section presents all our exciters, allowing the creation of a sound wave by the vibration of a surface. Many brands are represented, allowing everyone to find a model that will suit his project. The filters on the page allow you to make a more precise selection according to your needs.
