Mono 2 Poles (Unité)
This connector will allow you to create Mono cables with 2.5mm jack. The cable must be soldered into the connector.
| Specifications | |
| Connector type | Jack 2.5mm male |
| Channels | 1 (Mono) |
| Connection type | To solder |
| Max cable diameter | 3.8mm |
| Total body length | 35mm |
| Material | Nickel |
| Color | Black |
| Max cable diameter (mm) | 3.8 |
| Mounting type | To weld |
| Connectic | Male |
| Contacts number | 2 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | None |
