ETI LEGATO 20 AMP IEC C19 Connector
ETI Research's Legato 20 AMP power connector is a top-of-the-range IEC C19 that accepts power cables up to Ø20mm. Its contacts are made of gold-plated 1100 (IACS 102%) copper for optimum conductivity and signal stability.
By buying this product you get 26 loyalty points
Reference : 20572
269,00 €tax incl.
224,17 € tax excl.
Shipping date: 25-06-2025.
ETI Legato 20 AMPIEC C19 Connector Gold Plated Copper Ø20mm
Photo du connecteur IEC ETI Legato
ETI Research's Legato 20 AMP power connector is a top-of-the-range IEC C19 that accepts power cables up to Ø20mm. Its contacts are made of gold-plated 1100 (IACS 102%) copper for optimum conductivity and signal stability. In addition, the connector body is made of 6061-grade aluminum with advanced shielding against EMI/RFI interference for the safest possible connection. This makes it an ideal choice for high-end audio systems, professional studios and industrial applications where signal integrity is essential.
Product typeIEC C19 connector
Contact material1100 copper (IACS 102%)
Contact platingGold
Max cable diameterØ20mm
Max. conductor diameterØ4mm (AWG 6, 13.3mm²)
Mounting ytpeTo screw
Dimensions100mm x Ø42mm
Package1x IEC C19 ETI Research Legato 20 AMP connector
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C19
Rated current (A)20.0
ETI LEGATO 20 AMP IEC C19 Connector Gold Plated Copper Ø20mm
ETI Research's Legato 20 AMP power connector is a top-of-the-range IEC C19 that accepts power cables up to Ø20mm. Its contacts are...
