toujours Top qualité avec Furutech, pas besoin d'aller chercher ailleurs
By buying this product you get 33 loyalty points
IEC Connector Pur Copper Gold Plated 24k Ø17.5mm
The Furutech FI-28 (G) is a very high performance IEC female connector, ideal for building an audiophile power cable without compromise. In addition to its gold-plated copper contacts, the FI-F28 also benefits from the proprietary Furutech Alpha α anti-magnetic treatment, which involves two steps:
The FI-28 model also uses the patented Floating Field Damper System technology, which almost completely eliminates the creation of micro-zones of magnetic and electrostatic turbulence inside the connector, caused by the passage of current in the vicinity of certain sensitive components (metal fixing screws, cable clamping elements, etc.). These "floating" micro-fields of force conflict with the much stronger primary magnetic flux generated by the passage of current through the cable and connectors, inducing a form of electrical resistance that is harmful to conductivity, as well as being able to generate a form of distortion. Furutech manages to control these phenomena by connecting all the metal parts concerned to each other by means of a conductor which is responsible for bringing all these undesirable energies to earth.
The body of the connector is made of a composite material of Nylon and Fiberglass, offering extreme resistance to shocks, electric arcs and high temperatures.
The conductors are fastened by means of 3 colour-coded screws (2 poles + earth). The firmness of the fixing, obtained thanks to the Furutech Wire Clamp technology, eliminates any risk of accidental tearing or damage to the cable, while significantly improving the contact surface.
The connector is compatible with cables between 6 and 17.5mm diameter.
Product type | IEC C15 connector |
Contacts material | Pure Copper |
Contacts plating | Gold 24k |
Treatment | Anti-magnetism Alpha α |
Technologies | Floating Field Damper System Wire Clamp (cable clamping technology. 17% improvement in contact surface area) |
Body material | Nylon and fiberglass |
Connection type | To screw |
Min/Max cable diameter | Ø6.6mm - Ø17.5mm |
Total dimensions | 76.2 x Ø39.6mm |
Rated Voltage/Current | 250V/10A 125V 15A |
Max cable diameter (mm) | 17.5 |
Mounting type | To screw |
Connectic | Female |
Connector | IEC C15 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Rated current (A) | 15.0 |
Rated current (A) | 10.0 |
Average votes 4.8 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Vincent F.
Vincent F.
Frank T.
Jean-Christian N.
