Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Marcus L.
Michael M.
Worth every penny!
mathieu l.
Schuko Connectors
Discover our range of Schuko power connectors, for the design of your HiFi power cables.
