HIDIZS MS2 PRO In-Ear Monitors Jack 3.5mm
-30%
The Hidizs MS2 Pro are wired in-ear headphones designed around a hybrid architecture with two transducers, one dynamic and one balanced armature, and a system of interchangeable acoustic filters, allowing the sound signature to be adjusted according to musical styles. This versatility is complemented by a ZA-12 zinc alloy body, ensuring both rigidity and a high-quality finish.
Reduced price!
Reference : 21355
84,90 €tax incl.
-30%
59,43 €tax incl.
49,53 € tax excl.
Shipping date: 12-11-2026.
Hidizs MS2 Pro Jack 3.5mm In-Ear Monitors IEM Dynamic Balanced Armature 17 Ohm 111dB 20Hz-40Hz
Hidizs MS2 Pro : Front view
Hidizs MS2 Pro: Hybrid acoustic design
The MS2 Pro combines two complementary transducers to cover the entire audible spectrum: a 10.2 mm dual-cavity dynamic transducer equipped with a PU+PEEK composite diaphragm with a nanometric DLC (diamond-like carbon) coating, and a Silvercore balanced armature transducer developed in-house by Hidizs for high-frequency reproduction. This hybrid architecture is based on a dual magnetic circuit that improves control of the dynamic driver, particularly in the bass registers. The whole unit is housed in a ZA-12 zinc alloy moulded body, whose rigidity limits parasitic resonances while ensuring a neat finish.
Hidizs MS2 Pro : Dynamic speaker
Hidizs MS2 Pro: Adaptable sound signature
Beyond this technical foundation, Hidizs offers three interchangeable acoustic filters that modify the acoustic response according to listening preferences. The transparent ring filter favours an airy and detailed soundstage, particularly suited to classical and acoustic music. This approach is transformed with the red ring filter, which warms the signature to better serve folk and pop. For those looking for more impact in the bass, the black ring filter accentuates the low registers, offering a more energetic presentation for rock and metal.
Hidizs MS2 Pro : Frequency response
Hidizs MS2 Pro : Pneumatic filter
Hidizs MS2 Pro: Silver-plated OFC copper cable
The MS2 PROs are equipped with a detachable 0.78mm 2-pin cable, making them compatible with most audiophile cables available on the market. The original cable is a silver-plated OFC twisted copper model, measuring approximately 1.2m. This model ends with an asymmetrical 3.5mm stereo jack connector.
Product typeIn-ear earphones
Drivers1x Dynamic Ø10.2mm
1x Balanced Armature
Dynamic driver diaphragmPU+PEEK with DLC coating
MagnetN52
Double magnetic circuit
Cable conductor materialSilver-plated OFC copper
Cable length1.2m
Earphone connectorCIEM 0.78mm 2 pins
Cable terminationJack 3.5mm
Frequency response20Hz - 40kHz
Sensitivity111dB
Impedance17Ω
Total harmonic distortion (THD)< 0.05% @1kHz
Earphone shell materialZA-12 zinc alloy
Weight~ 26g
Package1x Hidizs MS2 Pro
1x Storage pouch
1x 3.5mm jack cable
3x Pairs of air filters
6x Pairs of silicone ear tips (Balanced / High frequencies)
Impedance (Ω)17
Efficiency / Sensitivity (dB)111
WirelessNo
Phone call featureNo
Noise reductionNo
HIDIZS MS2 PRO In-Ear Monitors IEM Dynamic Balanced Armature Jack 3.5mm 17 Ohm 111dB 20Hz-40Hz
The Hidizs MS2 Pro are wired in-ear headphones designed around a hybrid architecture with two transducers, one dynamic and one balanced armature,...
