DOUK AUDIO BSA-600 Amplifier for Exciter Bass Shaker
With the BSA-600, Douk Audio offers an integrated amplifier based on a TPA3255 chip and specially designed to power bass shaker. It can deliver up to 230W of power in bridged mono mode and 2x115W in stereo mode and incorporates an adjustable low-pass filter from 50Hz to 200Hz, allowing you to fine-tune your setup.
By buying this product you get 26 loyalty points
Reference : 21343
265,00 €tax incl.
220,83 € tax excl.
Douk Audio BSA-600 Class D Amplifier for Exciter Bass Shaker Stereo 2x165W 4 Ohm / Mono 230W 2 Ohm
Douk Audio BSA-600 : Front view
Douk Audio BSA-600 : Possible connection
Depending on the connections selected, the BSA-600 can drive up to 4 bass shaker in mono mode and 8 in stereo mode. In addition, to provide the best possible experience, the amplifier comes with a wired remote control.
Product typeIntegrated amplifier for bass shaker
InputStereo RCA
OutputStereo RCA
Speaker terminals
Output powerStereo: 2x115W @ 4Ω
Mono: 230W @ 2Ω
Matched speaker impedance2-8Ω
Range of cutoff frequency50-200Hz
Input sensitivity0.22mV @ 50Hz
Gain40dB
Total harmonic distortion (THD)0.1%
Signal-to-noise ratio (SNR)≥ 105dB
USB output voltage5V DC
ProtectionOverheat
Overcurrent
Power supply voltage100-240V AC
Weight2.34kg
Package1x Douk Audio BSA-600
1x Wired remote control
1x 5m USB-C to USB-C cable
1x Power cable
Mounting accessory
OutputSpeaker terminal
Channel1 (Mono)
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)165.0
Power (W)230.0
Remote ControlYes
DOUK AUDIO BSA-600 Class D Amplifier for Exciter Bass Shaker Stereo 2x165W 4 Ohm / Mono 230W 2 Ohm
With the BSA-600, Douk Audio offers an integrated amplifier based on a TPA3255 chip and specially designed to power bass shaker. It can deliver up...
