SMSL PL20 CD Player Ripper Silver
The SMSL PL20 is positioned as a versatile CD player combining a dual CS43131 DAC architecture with a built-in ripper function, while ensuring DSD compatibility for high-resolution formats. This technical foundation is accompanied by extensive connectivity, from bidirectional Bluetooth to USB playback of DSD64 files, complemented by two dedicated headphone outputs in 3.5 mm and 4.4 mm balanced jacks. The unit can therefore be used with both physical media and digital sources, with the option of switching to an external DAC thanks to the optical and coaxial outputs.
By buying this product you get 20 loyalty points
Reference : 21354
207,90 €tax incl.
173,25 € tax excl.
Shipping date: 17-11-2026.
SMSL PL20 CD Player Ripper 2xCS43131 Silver
SMSL PL20 : Front view
The SMSL PL20 is positioned as a versatile CD player combining a dual CS43131 DAC architecture with a built-in ripper function, while ensuring DSD compatibility for high-resolution formats. This technical foundation is accompanied by extensive connectivity, from bidirectional Bluetooth to USB playback of DSD64 files, complemented by two dedicated headphone outputs in single-ended 3.5mm and balanced 4.4mm jacks. The unit can therefore be used with both physical media and digital sources, with the option of switching to an external DAC thanks to the optical and coaxial outputs.
SMSL PL20: A high-performance CD player
The PL20 is built around two CS43131 DAC chips that process audio signals from CDs. Beyond simple playback, the device includes a ripping function that allows tracks to be extracted directly to a connected USB flash drive. This practical approach is extended with DSD compatibility, which opens up access to high-resolution formats on physical media. For those who wish to use a dedicated converter, optical and coaxial digital outputs allow conversion to be transferred to an external DAC.
SMSL PL20 : In use
SMSL PL20 with a USB flash drive connected
SMSL PL20: Complete connectivity
Connectivity also extends to wireless devices thanks to bidirectional Bluetooth 5.3, which can receive audio streams from a smartphone and transmit the signal to wireless speakers or headphones. This versatility is also found on the USB port, which accepts not only DSD64 (DFF/DSF) files, but also common formats such as WAV, FLAC, APE, WMA and MP3. For headphone listening, two outputs complete the connectivity options: a 3.5 mm jack and a 4.4 mm balanced output, allowing direct connection to any headphones without the need for an adapter.
Product typeCD player
Ripper
InputsCD player
1x USB-A
Bluetooth
Outputs1x Stereo RCA
1x 3.5mm headphone jack output
1x 4.4mm headphone jack output
1x Optical Toslink
1x Coaxial
Bluetooth
Bluetooth version5.3
Supported file formatsCD: CD-DA / CD-ROM / CR-R / CD-RW
File: DSD64(DFF/DSF) / WAV / FLAC / APE / WMA / MP3
DAC chips2x CS43131
Output powerJack 4.4mm: 160mW @ 32Ω
Jack 3.5mm: 40mW @ 32Ω
Total harmonic distortion moire noise (THD+N)0.0012%
Signal-to-noise ratio (SNR)98dB
Power supply5V DC / 2A
Consumption< 3.5W
Dimensions166.3 x 49.5 x 209.3mm
Weight1.4kg
ColorSilver
Package1x SMSL PL20
1x Remote control
1x USB-A to USB-C cable
The SMSL PL20 is positioned as a versatile CD player combining a dual CS43131 DAC architecture with a built-in ripper function, while...
