ETI LEGATO Schuko Type E/F Power Connector Gold Plated Pure Copper Ø20mm
The ETI Legato Schuko connector benefits from a high-end construction based on the use of high quality components for optimal conductivity. Thus, the contacts of the connector are made of high purity 1100 Copper with an IACS rating of 102%.
Reference : 14312
245,00 €tax incl.
204,17 € tax excl.
Shipping date: 20-06-2025.
ETI Legato
Power Connector Schuko Gold Plated Pure Copper Ø20mm
ETI Legato Connecteur Secteur Schuko Cuivre Pur Plaqué Or Ø20mm
The ETI Legato Schuko connector benefits from a high-end construction based on the use of high quality components for optimal conductivity. Thus, the contacts of the connector are made of high purity 1100 Copper with an IACS rating of 102%. They are also gold plated, protecting them from oxidation while maintaining excellent conductivity. The body of the connector is made of machined 6061 Aluminum and is designed to limit the impact of EMI/RFI interference on the signal.
Product typeSchuko connector
Contacts materialCopper 1100 series (IACS 102%)
Contacts platingGold
Body materialAluminium 6061 series
Max cable diameterØ20mm
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)N/A
6 reviews
Mes notes par critere
ETI schuko en dynamique vitesse 9.5 , punch impact 6.5 , neutralité 9.5 , matiere relief 7 , transparence 9.5 , timbre 9 , douceur 8, precision details 9, basse 9, finition 9.5 si ça peut aider quelqu un
This review has been posted for ETI LEGATO Schuko Type E/F Power Connector Gold Plated Pure Copper Ø20mm
Enfin de l or rapide ,transparent et neutre!!!!!
Bonjour ,schuko ETI avec un vondita et une iec 004 , sur mon alimentation ,resultat la ETI a une tonalité fine, tres rapide, tres transparente, detaillé, beau timbre du haut, vraiment differente des autres or ( fi38 or ,iego or, etc) Elle est plus neutre ! Je la conseille avec une 004 oyaide , pas trop sur une barette, une des meilleures schukos que j ai entendu avec la 004 oyaide . 004 ,ETI; FI38R mes fetiches
First class connectors
Used on a Furutech 762 AC cable. Very neutral, very dinamic sound. Very good connection points and very clever and efficient cable holding system. Used on Amplifier.
Superb mechanical and audible quality
Solid and stable mechanical construction. Everything fits here, easy but efficient. Hugh difference in regard to "gold plated" compared to other connectors!
Tonal very fine, well balanced and detailed - best connectors I ever bought!
Superbe produit
Qualité de fabrication irréprochable permettant une haute qualité de contact et d'assemblage avec le câble secteur. Transparence et qualité de timbrage superbe par une transparence hors norme. A mon sens, plus neutre que les connectiques Furutech, sans nier leurs qualités également. Superbe mariage avec le secteur DPS 4.1 Furutech avec un apport concret dès la mise sous tension. Bravo !!
The ETI Legato Schuko connector benefits from a high-end construction based on the use of high quality components for optimal conductivity. Thus,...
