Schuko F-Type Power Connector 230V 16A Ø15mm
This low-cost Schuko power connector is ideal for designing your own power supply cables without breaking the bank. The practical rubber tip of this model can be cut according to the diameter of your cable, up to 16mm. It also allows a good hold of your cable in the connector.
Reference : 16856
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 05-05-2026.
Power connector
Schuko F-Type 230V 16A Ø16mm
Connecteur Secteur Schuko 230V 16A Ø16mm
APlease note that this connector is only compatible with German schuko plugs, which are grounded on the side of the plug.
Product typeSchuko power connector F-Type
Max cable diameterØ16mm
Mounting typeTo screw
Body materialPlastic
Total dimensionsØ42 x 103mm
Max cable diameter (mm)15.0
ConnecticMale
ConnectorSchuko
Rated current (A)16.0
This low-cost Schuko power connector is ideal for designing your own power supply cables without breaking the bank. The practical rubber tip of...
