WATTGATE 390I AG Schuko Connector Triple Plating OFC Copper Nickel Silver Cryo Treatment Ø16mm
Reference : 13146
85,00 €tax incl.
70,83 € tax excl.
WATTGATE 390I AG
Schuko Connector Triple Plating OFC Copper Nickel Silver Cryo Treatment Ø 16mm
WATTGATE 390I AG Connecteur Schuko Triple Plaquage Cuivre OFC Nickel Argent Traitement Cryo
The Schuko Wattgate 390i AG mains connector is a resolutely high-end model with a very high design and design quality. This is an ideal model for anyone who wants to create high performance power cables and provide a clean electrical signal to a system for quality reproduction.
Practical and efficient
Convenient connector
The connector is equipped with screw terminals, allowing quick and easy assembly of cables, not requiring soldering.
Triple plating
The connector contacts have triple plating. There is an OFC copper layer to obtain a very good conductivity, an electrolytic nickel intermediate layer to isolate the other two layers from each other and finally a last layer of silver to further increase the conductivity but also the resistance of the contacts to oxidation.
Effective cable clamp
The back of the connector benefits from a cable clamp adaptable according to the diameter used. This firmly holds the cable in place to protect it during handling. The connector accepts cables with a maximum diameter of 16mm and a cross-section of 10 to 16AWG.
Insérer texte alternatif ici
Cryo Treated
This Wattgate connector benefits from the Cryo treatment developed by the brand, the Deep Cryogenic Treatment (DCT) method. This is a cryogenic treatment with nitrogen that must follow a very specific cycle in order to increase conductivity. In this method, the brand takes care never to put in direct contact the part treated with nitrogen in order to avoid thermal shocks. This process takes 4 to 5 days to achieve an exceptional result.
Dimensions
Connector typeSchuko connector
Contacts platingTriple plating :
  1. OFC Copper
  2. Electroless Nickel
  3. Silver
Max cable diameter16mm
Acceptable cable section10 to 16AWG
Current / Voltage16A / 250V AC
Body materialNylon and polycarbonate
Cryo treatmentYes - DCT
Connection typeTo screw
ColorBlack and blue
Dimensions8.3 x Ø 3.8cm
Dimensions & distances
Spacing connector Wattgate 390I AG
Max cable diameter (mm)16.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
