FX-AUDIO D2160 MKII FDA Amplifier Bluetooth 5.0 Class D TAS5614 2x100W 4 Ohm Black
FX-Audio returns with a new Full Digital Amplifier (FDA): the D2160. This one is directly following its big brother, the FX-Audio D802C, proposing notably more power, audio performances always excellent and functionalities more accomplished.
4.6 / 5
Reference : 12689
249,00 €tax incl.
207,50 € tax excl.
FX-AUDIO D2160 mkii
FDA Amplifier Bluetooth TAS5614 2x125W 4Ω
fx-audio d2160
FX-Audio returns with a new Full Digital Amplifier (FDA) : the D2160 MKII . This one is directly following its big brother, the FX-Audio D802C, proposing notably more power, audio performances always excellent and functionalities more accomplished.
TAS5614 & Quality components
The FX-Audio D2160 is based on a TAS5614 amplification chip . This allows this FDA to provide 2x60W at 8Ω or 2x100W at 4Ω. It provides clear and precise sound, while offering deep bass. Thus, the amplifier provides an SNR of -103dB, a THD of 0.01% and a frequency response of 20Hz - 20kHz. The TAS5614 is backed by a STM32 microcontroller (MCU)
Also included in this amplifier is a CM6642 USB chip, an ADC TI PCM1808 for the analog input, a Maxim MAX9722 amplification chip for the headphone output, and AKM AK4118 Toslink coaxial / optical receiver.
Bluetooth : Your music from your sofa
Equipped with a Bluetooth 5.0 CSR8675 chip especially designed for audio, the FX-Audio D2160 will allow you to enjoy your music directly from your sofa. A simple pairing of your reading device (smartphone, tablet ...) to your amplifier and the music starts.
Furthermore, the Bluetooth chip standard 5.0 and its A2DP protocol ensures higher transmission speed and greater stability for better quality audio reproduction. More than that, the chip integrates the technologies aptX and aptX Low-Latency, aptX HD & LDAC, allowing a support up to 24bit-96kHz.
An antenna supplied with the camera is attached to the rear to extend the transmission distance.
Effective audio features
The FX-Audio amplifier offers simple but very effective audio features. With its DSP TAS5548 , the device proposes to modify the bass and treble curve. A "HiFi" mode is also present, corresponding to a Direct Audio mode to bypass the DSP and enjoy a perfect respect of the original signal.
Complete connectivity
The D2160 offers a complete connection that will allow you to connect your system without worry. We thus find in input a Toslink Optics, a Coaxial, a USB-B and a Stereo RCA. An outlet can also connect the antenna to enjoy a greater transmission distance.
Audio Output
On the output side, nothing could be simpler since we find on one side connectors accepting banana plugs to connect your speakers, a subwoofer output on RCA and on the other side a 6.35mm jack connector to connect headphones.
FX-Audio D2160 Connectique
Remote control
It would be a shame to be able to stream your music directly from your couch but having to get up to change the source or adjust the volume, right? FX-Audio has thought and provided with the amp an IR remote control. This will allow you to access all the features of your device, namely control of volume and sources, adjusting the bass and treble or switching to "Hifi" or "Mute" mode.
A simple and strong design
The FX-Audio offers with its D2160 a simple design that allows it to integrate seamlessly into the vast majority of audio systems, while unveiling a stronger side with the integration on its sides of two heatsinks . Heatsinks that are also not irrelevant since they allow the amplifier to effectively evacuate the heat released.
With a 100% brushed aluminum housing, the amplifier promises to be robust and will perfectly protect the internal components of the dust.
FX-Audio D2160 review by Qobuz
" FX-Audio offers us two amplifiers in one. In Tone On mode, a device with a more or less modular restitution, a little round, softened and more or less convincing, it is up to everyone to decide. In Hi-Fi mode, a device with a sharp sound reproduction, as close to the signal as we like, and to which we would have granted our reward. "
Test Qobuz
Amplifier typeFDA (Full Digital Amplifier)
Amplifier chipTAS5614
MCUSTM32
DSPTAS5548
SPDIF ChipAK4118
USB ChipCM6642
Bluetooth chipCSR8675
Headphone amplifier chipMAX9722
Power2x60W at 8Ω / 2x100W at 4Ω (@ THD 10%)
SNR-103dB
THD0.01%
Frequency response20Hz - 20kHz at -2dB
Headphone output power60mW at 32Ω
Headphone output SNR-93dB
Headphone output THD0.02%
Connectors : Inputs
USB-B1x (OTG)
Optical1x
Coaxial1x
RCA Stereo1x
Bluetooth-
Connectors : Outputs
Borniers enceintes-
Headphone connectorJack 6.35mm
Subwoofer output-
Power supplyJack DC 5.5/2.5mm
DC 36V 6A (included)
Dimensions (without antenna)23.8 x 19.5 x 4.5cm
Weight1840g
Package1x Power supply adapter
1x male USB-A to male USB-B
OutputSpeaker terminal
OutputJack 6.35mm
Channel2 (Stereo)
Power (W)65.0
Remote ControlYes
13 reviews
Étonnant !
C'est mon premier amplificateur, donc forcément je n'ai pas une oreille extrêmement avertit mais j'ai étais réellement bluffé par ce petit ampli qui paraît minuscule a première vue mais qui surprend par la puissance et la qualité qu'il renferme !
Seul bémol la télécommande fournit avec l'ampli était H.S mais le SAV Audiophonics m'en a expédié une nouvelle le jour même que j'ai reçu très rapidement et qui est bien fonctionnelle donc merci beaucoup à la qualité de leur service !
This review has been posted for FX-AUDIO D2160 MKII FDA Amplifier Bluetooth 5.0 Class D TAS5614 2x100W 4 Ohm Black
Etonnant de qualité
Curieux de nature, j'ai voulu tester un ampli FDA. Sans a priori d'ailleurs.
Et là, j'avoue que j'ai été très heureusement surpris. Par la robustesse de l'objet, d'une part, mais aussi par le rendu. c'est musical, clair. Et puis, ça ne manque pas de puissance. Je suis tout simplement impressionné !
C'est un voyage musical diffèrent d'avec mon Atoll ou mon Jadis Orchestra. Il vient en complément, mais en aucun en mode "low cot". Pour le prix, c'est une véritable révélation. Et même en Bluetooth c'est très correct.
Bref, de la qualité. Bravo !
Excellent
Très bon rapport qualité prix.
Complément
Un complément d'information suite à utilisation de l'entrée AUX avec un lecteur de CD Technics; câble RCA Monster 400; ampli en high; très bon son qui confirme pour moi la grande qualité de cet ampli.
Application Android
Après quelques mois d'utilisation mon ampli fonctionne toujours aussi bien, je complète mon avis pour savoir s'il serait possible au constructeur de mettre à disposition une application Android qui permettrait de piloter l'ampli avec un smartphone?
FX-Audio returns with a new Full Digital Amplifier (FDA): the D2160. This one is directly following its big brother, the FX-Audio D802C, proposing...
