SMSL VMV A2 FDA Amplifier Bluetooth aptX-HD LDAC UAT Subwoofer 2x200W 4 Ohm
SMSL offers with its A2 a high-end full digital amplifier, integrating only audiophile quality components in a robust and design chassis made of CNC machined aluminum. Complete, versatile and powerful, the A2 adapts to all needs and all systems, while offering a rich and precise sound reproduction.
By buying this product you get 99 loyalty points
Reference : 15448
999,00 €tax incl.
832,50 € tax excl.
SMSL vmv A2
FDA Amplifier Bluetooth aptX-HD LDAC UAT 2x200W 4 Ohm
SMSL offers with its A2 a high-end Class D amplifier, integrating only audiophile quality components in a robust and design chassis made of CNC machined aluminum. Complete, versatile and powerful, the A2 adapts to all needs and all systems, while offering a rich and precise sound reproduction.
SMSL A2 Amplificateur Class D Bluetooth aptX-HD LDAC UAT 2x200W 4 Ohm
Digital feedback
The SMSL A2 uses an ingenious digital feedback technology. This technology allows a drastic reduction of the distortion level for an incredibly pure sound reproduction.
Bluetooth
Embedding a high quality Qualcomm Bluetooth chip, the A2 supports many Bluetooth codecs. In addition to the classic AAC and SBC codecs, it also supports aptX, aptX-HD, LDAC and UAT, allowing for excellent wireless sound quality.
SMSL A2 Amplificateur Class D Bluetooth aptX-HD LDAC UAT 2x200W 4 Ohm SMSL A2 Amplificateur Class D Bluetooth aptX-HD LDAC UAT 2x200W 4 Ohm SMSL A2 Amplificateur Class D Bluetooth aptX-HD LDAC UAT 2x200W 4 Ohm SMSL A2 Amplificateur Class D Bluetooth aptX-HD LDAC UAT 2x200W 4 Ohm
Equalizers and presets
The SMSL A2 provides different predefined equalization profiles to adapt to your listening and your audio system. For a personalized setting, it also allows to adjust the bass and treble levels.
Amplifier & DSP
The A2 uses a powerful amplifier chip, combined with a state-of-the-art DSP developed with great care, to achieve a very low distortion level of 0.0008%.
XMOS
The USB-B input of the A2 is associated with a second generation XMOS interface, supporting high sampling rates, up to 32bit 768kHz PCM and native DSD512.
PCM1804 ADC
The analog input of the SMSL A2 uses a Texas Instruments PCM1804 ADC chip, with a filtering circuit composed of three OPA1678 low noise AOPs, for a perfectly clear sound reproduction, even in analog.
Optimized power supply
The A2 uses a professional LLC power supply especially suited for power amplifiers. It also features active PFC circuitry and an advanced EMI filter to stabilize the output and reduce interference. Finally, the power supply stage benefits from a complete protection circuit with optimized heat dissipation for a stable and reliable power supply.
1Screen
2IR Receiver
3Input selector
4Bluetooth button
5Standby LED
6Multifunction knob
7Power connector (100-240V AC)
8Left speaker output
9Right speaker output
10USB Input
11Coaxial input / Subwoofer output
12AES Input
13Single-ended RCA input
14Optical input
15Bluetooth antenna
Test du SMSL VMV A2 par Audio Science Review (Amir)
SMSL pushes the boundaries of desktop amplifiers producing a powerful and very clean design if you use digital input. "
Product typeAmplifier
Amplifier typeClass D
Inputs1x USB-B
1x Optical
1x Coaxial
1x AES
1x Stereo line RCA
OutputSpeaker terminals
THD+N0.0008%
SNR115dB
Channel separation108dB
Output power2x 200W @ 4Ω
2x 100W @ 8Ω
USB Transmission modeAsynchronous
USB CompatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz
Supported Bluetooth codecsAAC, SBC, aptX, aptX-HD, LDAC, UAT
Dimensions280 x 255 x 43mm
Weight2.6kg
Package1x SMSL A2
1x Schuko power cable
1x Remote control
InputAES/EBU
Channel2 (Stereo)
Channel2.1
Amplifier chipN/A
Power (W)200.0
Remote ControlYes
Ampli FDA Smsl VMV A2
J'avais un ampli Atoll in 200 élément principal d'écoute avec des magnepan MG12.
Je voulais tester le FDA et comme ce sont des enceintes à bas rendement j'ai pris le plus puissant.
Après quelques minutes d'écoute j'ai été d'abord surpris presque déçu hésitant et j'ai compris que la source d'enregistrement était très importante.
Il reproduit avec justesse et rapidité le morceau enregistré s'il est de qualité.
Donc transparence sans coloration neutre.
Il chauffe peu très silencieux.
Beaucoup de connexions.
Sortie sub parfaite.
J'ai revendu l Atoll.
J'en suis très satisfait.
A noter que je n'écoute que du numérique mais il est fabriqué pour ça.
Le FDA est vraiment formidable.
J'espère une version à venir encore plus puissante.
Au 3/4 du volume il coupe.
Mais bon 86 db en 4 ohms c'est normal.
Je n'ai pas encore testé avec le caisson de basses à volume élevé pour voir si la coupure se fait au même niveau.
J'ai remplacé les pointes pas très esthétique je trouve par des pieds ronds plus sympa au visuel et pratique à déplacer.
Les pointes sont sur des petites coupelles aimantées.
Rapport qualité prix excellent.
Un grand merci à monsieur David Aubert toujours disponible et réactif aux milles questions que l'on se pose pour nos oreilles jamais rassasiées.
This review has been posted for SMSL VMV A2 FDA Amplifier Bluetooth aptX-HD LDAC UAT Subwoofer 2x200W 4 Ohm
SMSL offers with its A2 a high-end full digital amplifier, integrating only audiophile quality components in a robust and design chassis made of...
