DAYTON AUDIO UM10-22 Ultimax DVC Speaker Driver Subwoofer 500W 2x2 Ohm 85dB 25Hz - 1500Hz Ø25cm
Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Enjoy the best value for money available !
Strengths:
  • Power consumption 500W on 4 Ohm (2 coils)
  • Resonance frequency 26.9Hz.
  • As efficient in Hifi use as Home Cinema.
  • Nomex cone low colouring
By buying this product you get 25 loyalty points
Reference : 12584
255,00 €tax incl.
212,50 € tax excl.
Ultimax
Subwoofer DVC 4Ω ⌀25cm 500W RMS
Dayton Audio UM10-22 25cm 500W RMS
This exceptional subwoofer with ultra rigid aerial chassis has powerful ceramic magnets. Its Nomex/glass fiber cone with high stiffness in honeycomb structure produces powerful bass, defined without harmful coloring. Thanks to its 2+2 coils system and its long linear elongation, this subwoofer is able to reach frequencies of 19.5Hz.
Technical caractheristics
Réponse en fréquence UM10-22 Ultimax
Type de haut parleurSubwoofer
Diamètre nominal25cm (10")
Matériau membraneNomex Glass fiber
Matériau aimantceramic ferrite
Total diameter273,5mm
Depth178mm
powerRMS : 500W on 4 ohm  2+2 coils
MAX : 1000W
Impedance4Ω
Sensibility84.8dB @ 2.83V/1m
frequency response25Hz - 1500Hz
Resistance DC (Re)3.2Ω
Inductance coil (Le)1.28mH @ 1kHz
Resonance frequency (Fs)26.9Hz
 (Qms)3.08
 (Qes)0.59
(Qts)0.49
Air load (Mms)227g
 (Cms)0.15 mm/N
Emmissive aera (Sd)327.8cm²
Air volume (Vd)622.8 cm3
Linear maximum exurcion (Xmax)19mm
Ultimax Dayton Audio UM10-22
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume16.57 Litres
Sealed F345 Hz
Vented Volume43.89 Litres
Vented F322 Hz
Speaker Power (W RMS)500.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)250.0
Diaphragm typeComposite alloy
Diaphragm typeGlass fiber
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)19.0
Lowest frequency (Hz)25
Highest frequency (Hz)1500
2 reviews
parfait si ce n'était le prix
Un sub qui en jette c'est sûr! aussi bien au propre qu'au figuré. Il est lourd, sérieusement construit et même beau pour être honnête avec son HP sans cache noyau et sa membrane épaisse. Comme tout bon HP SQ il est malheureusement lourd et nécessite un ampli qui a du courant. Je l'alimente avec un vieux infinity numérique bien droit, dans un caisson clos d'environ 25L il fait des merveilles avec une belle descente et une articulation propre et détaillée agrémenté d'une belle ampleur. Il sera parfait aussi bien pour restituer les basses profondes d'un James Blake que les kicks énervés et frénétiques d'un bloc party ou d'un blink 182. Le prix est à la hauteur de la prestation mais pour le non initiés qui n'y verra que du feu, un dayton de la gamme LS fera déjà un excellent travail.
This review has been posted for DAYTON AUDIO UM10-22 Ultimax DVC Speaker Driver Subwoofer 500W 2x2 Ohm 85dB 25Hz - 1500Hz Ø25cm
Parfait
Il se sera fait attendre mais ça en valait la peine.
installé dans un caisson clos dans une voiture et alimenté seulement par un petit Focal FDS 2.350 (ponté) il fait mon bonheur.
Franchement je ne regrette absolument pas, bien au contraire au vu du rendu, trés qualitatif aussi bien physiquement qu'auditivement.
Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Enjoy the...
