DAYTON AUDIO PCS12-4 Subwoofer Speaker
The Dayton Audio PCS12-4 is a 30.48cm (12") paper cone subwoofer speaker, designed for DIY projects and multi-way systems seeking deep bass extension, high output level and easy integration. Its polypropylene-coated paper cone, combined with an inverted dust cap of the same finish, produces energetic bass while retaining a sober appearance, while the 30 Hz resonance frequency promotes an extended response in a properly designed enclosure.
Reference : 22504
64,90 €tax incl.
54,08 € tax excl.
Grantie 5 ans
DAYTON AUDIO PCS12-4 Subwoofer Speaker 180W 4 Ohm 90.6dB 25Hz-300Hz
DAYTON AUDIO PCS12-4: Front view
With a sensitivity of 90.6 dB, an impedance of 4 Ω, a 7 mm Xmax and a power handling of 180 W RMS, it delivers significant impact without requiring oversized amplification. Its wide-roll rubber surround accompanies the movements of the cone in order to maintain controlled excursion, while the fully vented motor improves heat dissipation during extended listening sessions. Finally, its low-profile stamped steel basket simplifies installation in a dedicated enclosure or in a custom build, to effectively reinforce the bass range of an audio system.
DAYTON AUDIO PCS12-4: Dimensions and measurements
Technical specifications
Product typeSubwoofer
Impedance4Ω
Sensitivity90.6dB 2.83V/1m
Frequency response25Hz-300Hz
Voice coil diameter3.81cm (1.5")
Nominal diameter30.48cm (12")
PowerRMS: 180W
MAX: 360W
Thiele-Small parameters
Resonance frequency (Fs)30Hz
Cone surface area (Sd)487cm²
Voice coil inductance (LE)2.1mH
DC resistance (Re)3.5Ω
Mechanical quality coefficient (Qms)6.4
Electromagnetic quality coefficient (Qes)0.75
Total quality coefficient (Qts)0.67
Force factor (BL)9.7T·m
Total moving mass + air load on the cone (Mms)106.5g
Mechanical compliance of suspension (Cms)0.26mm/N
Compliance equivalent volume (Vas)3.14ft³
Max linear excursion (Xmax)7mm
Mounting informations
Cutout diameter27.43cm (10.8")
Depth13.59cm (5.35")
Number of mounting holes8
Total external diameter32.38cm (12.75")
Materials
DiaphragmTreated paper
MagnetFerrite
FrameSteel
SurroundRubber
Voice coil wireCopper
Recommended Enclosure Volume
Sealed Volume11.32L (0.4ft³)
Sealed F371Hz
Vented Volume28.31L (1ft³)
Vented F335Hz
Weight3.7kg
PackageSold individually
Speaker Power (W RMS)180.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)304.8
Diaphragm typePaper
Efficiency / Sensitivity (dB)90.6
Max Linear Excursion (Xmax) (mm)7.0
Lowest frequency (Hz)25
Highest frequency (Hz)300
The Dayton Audio PCS12-4 is a 30.48cm (12") paper cone subwoofer speaker, designed for DIY projects and multi-way systems seeking deep bass...
