Audio extractor HDMI / MHL to I2S / Coaxial / Optical 4K 60Hz
4.7 / 5
Reference : 13419
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 07-04-2026.
Module HDMI extractor to I2S / Coax / Optics
HDMI A / V to I2S audio / Coaxial / Optical / HDMI - Compatible MHL
Extractor HDMI digital interface unit
This module is an HDMI extractor. It allows to recover the digital audio stream of a digital HDMI source (including MHL) towards a digital coax port / optical or HDMI (I2S via HDMI).
This interface will be particularly useful in complex home theater installations, where multiple sources are likely to successively vary between audio and video functions.
This type of module is ideal in that it separates the video and audio streams to convenience while maintaining appropriate audio formats for advanced facilities.
It has a function of ressampling to select between an output 2-channel / 5.1 channels or audio output corresponding to the input (bypass).
Explanation of the 3 selectable modes:
- TV: sends audio through HDMI to the TV, and does not extract audio on the SPDIF output
- AMP : extracts stereo audio (2 channels) to the audio outputs
- DOU: outputs 5.1-channel audio to the audio outputs
EP92A3E Chip
The function of extracting the audio signal to digital output is performed by an EP92A3E chip, complying with the HDMI 1.4 standard. This component is compatible with both single HDMI inputs and MHL 2.0 sources (HDMI to USB adapter typically used to connect a smartphone to an HDMI input).
The EP92A3E chip is capable of addressing different digital protocols, requiring several levels of signal accuracy. It has an HDMI repeater function, which also allows longer cables to be used to cover a greater distance. Its great compatibility with digital audio protocols makes it a very practical accessory to be prepared for any audio/video connectivity problem. It also provides the module with LPCM, HD audio & DSD Audio support. The Audio Soft mute approach is also supported.
Complete Connectivity
The connectivity of this interface is rich in possibilities since it offers the possibility to retrieve the digital audio stream via S/PDIF to a Toslink Optical connector as well as a Coaxial connector already mounted on the board. The I2S output via HDMI LVDS can also be used as a basic output via an HDMI connector already mounted on the PCB. Also two I2S / DSD outputs are available. One is connected to an XH 2.54mm 6-pin male connector; the second is in the form of solder pads.
The I2S LVDS via HDMI connectivity of this device uses the PSAudio format.
TypeHDMI extractor
InputsHDMI
OutputsHDMI / LVDS I2S PS AUDIO Format / Optical / Coax / I2S
HDMI video output compatibility4K 60Hz 3D CEC
Power Supply5VDC (Not provided)
Power connectorJack DC 5.5 / 2.5mm
Dimensions86.2 x 67.15 mm
Parts supplied
HDMI Modulex1
InputHDMI
OutputI2S LVDS via HDMI
OutputHDMI
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S
Max sampling rateNC
15 reviews
Simple et efficace
Facile à installer, cet extracteur intercalé entre mon AppleTV et ma TV me permet de diriger le son vers l'entrée coaxiale de mon Eversolo
This review has been posted for Audio extractor HDMI / MHL to I2S / Coaxial / Optical 4K 60Hz
Useful thing
The extractor did its job. You don't have to spend a lot of money on fancy HDMI i2S cables, because it works on inexpensive, well-made cables. The extractor allows you to extract DSD files from SACDs (finally!). You can connect it directly to a Blu-ray HDD or SSD and listen to music saved in DSD without using a computer. The only limitation is that you can only play DSD64 files, the higher ones, at least for me, are played in 176kHz pcm. And the power supply is necessary, because supposedly power goes through HDMI, but there are problems. So the power supply is a must.
Extraction directe au format DSD 2.8Mbits des SACD sur optique/coax à condition de le coupler avec une carte additionelle
Pour ceux qui n'ont pas d entrée HDMI sur leur DAC, j ai couplé ce dispositif au module additionel Interface / DAC ES9038Q2M I2S vers SPDIF / RCA vendu chez audiophonics également (https://www.audiophonics.fr/fr/modules-interfaces/module-interface-dac-es9038q2m-i2s-vers-spdif-rca-p-17046.html) via le connecteur I2S fourni. Résultats : flux DSD 2.8Mbits reconnu par mon DAC Teac UD701N depuis un lecteur blueray Sony UBP X500. Prévoir 2 alim 12V (https://www.audiophonics.fr/fr/adaptateurs-secteur/ifi-audio-ipower-mk2-adaptateur-secteur-alimentation-audio-faible-bruit-12v-18a-p-15500.html) pour alimenter le module. Parfait
Flawless transaction
I wanted to capture the audio out from my AppleTV and send it to my DAC via i2s. This device helped me to achieve that goal. It required one extra hdmi cable in the signal as well as a second hdmi cable to handle the i2s duties. I also needed a 5V power supply that wasn’t included. I was shocked at how quickly the unit was delivered.
Great solution
The item is for me a great solution for hearing SACDs in stereo (mostly with headphones) directly from my Cambridge Audio 752 BD through the Holo Audio May without any conversion to PCM.
In the May you've to set the I2S to ALT2 and then it's working without any problems.
