By buying this product you get 28 loyalty points
Scaler SCART to HDMI
CYP CSLUX-1080P is a video scaler which is very useful to connect properly any A/V device with a SCART output to a modern display with HDMI input.
It is able to perform high-precision video stream conversion and can adapt your low-definition sources to meet the standards of your high-definition display or TV (HDTV and resolutions up to 1080p/WUXGA). It supports NTSC, PAL and can perform an upscalling up to HDMI HDTV 1080p with a color bit depth of 8/10/12 bit up to a distance of 6 meters.
This scaler is really easy to use since it is able to detect the your display / monitor / TV settings (EDID native resolution ) and can switch automatically to the best resolution and framerate. 6 DELs located on the front panel show in real-time the output resolution.
This video Scaler supports 3D adaptive deinterlacing technology and framerate conversions : 3/2 : 2/2.
Type | Video Scaler |
Inputs | 1x SCART |
Outputs | 1x HDMI |
HDMI standard | 1.3/1.4 |
Supported Input formats | NTSC, PAL |
Video output resolution | 576P / 720P / 1080I / 1080P |
Power Supply | 5V / 2.6A DC |
Power Consumption | 6W |
Housing | Aluminum |
Color | Black |
Dimensions | 151mmx125mmx30mm |
Weight | 340g |
Package contents | |
1x | Scaler SCART / HDMI |
1x | Power Supply |
1x | Manual |
