Parfait pour extraire le son d'une sortie HDMI (ARC) d'un téléviseur ou rétroprojecteur, et l'injecter en optique dans un ampli. Ca marche !
HDMI ARC to SPDIF Coaxial Optical RCA Jack 3.5mm DTS Dolby AC-3 5.1
This compact audio extractor will allow you to simply extract the audio signal from an HDMI ARC input stream and then output to Coaxial, Optical, RCA stereo or an amplified 3.5mm jack headphone output. The careful design of the unit allows it to support high sample rates up to 192kHz and also supports DTS and Dolby 5.1 formats on the Optical and Coaxial outputs.
Product type | HDMI Splitter |
Input | 1x HDMI ARC |
Outputs | 1x Coaxial 1x Optical 1x Stereo RCA 1x Jack 3.5mm |
Max supported sampling rate | 192kHz |
5.1 Support | Via Optical and Coaxial |
Dimensions | 81.7 x 67 x 21.2mm |
Weight | 115g |
Case material | Aluminium |
Color | Black |
Power supply | 5V DC via Micro USB |
Package | 1x HDMI Splitter 1x USB-A to Micro USB cable |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Alexis J.
