TRN BT30 PRO Bluetooth 5.2 Receiver for IEM MMCX
New
TRN BT30 Pro are Bluetooth receivers for IEM headphones with MMCX connectors. These Bluetooth receivers are based on a Qualcomm QCC3040 chip as well as their own amplification thanks to a MAX97220A chip. As a result, they support AAC, SBC and aptX codecs for the most reliable and stable wireless transmission, while delivering a power output of over 42mW @ 16ohm.
Reference : 20780
49,00 €tax incl.
40,83 € tax excl.
Photo of the bluetooth receiver for IEM TRN BT30 PRO
TRN
 BT30 Pro
are Bluetooth receivers for IEM earphones with MMCX connectors. These Bluetooth receivers are based on a Qualcomm QCC3040 chip as well as their own amplification thanks to a MAX97220A chip. As a result, they support AAC, SBC and aptX codecs for the most reliable and stable wireless transmission, while delivering a power output of over 42mW under 16ohm. Added to this is Qualcomm CVC 8.0 noise cancellation technology for optimized rendering and clear voices during your phone calls. Their battery offers up to 6.5 hours of use on a 1.5-hour charge. As for the charging capacity of the box, it offers up to 1200mAh of charging capacity for a total of 32h of use of the Bluetooth receivers with it. In terms of ergonomics and comfort, TRN Bluetooth receivers offer a secure fit for earphones, and are covered with a water- and sun-resistant nano-coating for extended outdoor life.
TRN BT30 PRO highlights
TRN BT30 PRO: a high-performance chipset
TRN BT30 PRO Bluetooth receivers are based on a Qualcomm QCC3040 chip and a MAX97220A amplifier chip. This chipset provides power and support for high-fidelity Bluetooth codecs, with a noise level of just under 9uV and an SNR of 98dB. Bluetooth 5.2 offers a range of up to 15m and support for high-definition SBC, AAC and aptX codecs.
The TRN BT30 PRO chipset
TRN BT30 PRO: noise cancellation technology
The BT30 Pro's internal microphone incorporates Qualcomm's cVc 8.0 noise reduction for optimized rendering and clear communication during phone calls.
TRN BT30 PRO noise cancellation technology
TRN BT30 PRO: comfort and strength
TRN BT30 Pro are made from a flexible thermoplastic elastomer that makes wearing your favorite IEM comfortable. In addition, a nano-layer protects them from water and perspiration for use in all circumstances.
Comfortable, durable Bluetooth receivers
Product typeBluetooth receiver for IEM
Bluetooth chipQCC3040
Headphone amplificationMAX97220A
ConnectorsMMCX
Bluetooth version5.2
Supported Bluetooth codecsSBC, AAC, aptX
Output power42mW @ 16 ohm
Bluetooth range15m
Charging5V 2A via USB-C (Charging box)
Load capacityBox: 1200mAh
Bluetooth receiver: 80mAh/piece
Standby autonomy180h
Time of use50h with box
13h with bluetooth modules only
Charging timeModules: 1.5h
Box: 2.5h
Wireless charging: 3.5h
Weight8g per module
Package1x Pair of TRN BT30 PRO Bluetooth modules
1x Charging/storage box
Bluetooth receiver assembly
OutputMMCX
DAC / ADC ChipNC
Supported Bluetooth codecsaptX
Supported Bluetooth codecsAAC
TRN BT30 Pro are Bluetooth receivers for IEM headphones with MMCX connectors. These Bluetooth receivers are based on a Qualcomm QCC3040...
