ElFIDELITY AXF-101 Ultra external USB 3.0 Booster Power Filter for PC
Elfidelity AXF-101 external USB 3.0 Booster Power Filter for PC
Reference : 10990
49,90 €tax incl.
41,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
the Elfidelity AXF-101 USB Booster is the perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). In external version in a metal case, out of all EMI pollution, it is a formidable tool to power properly the 5V of any USB 3.0 audio and USB 2.0 audio device (USB / i2S interface, USB / SPDIF, DAC).
Based on very high-end components and connections, it allows to isolate and clean the USB port of the noise generated by the switched-mode power supply coming from a PC, from a portable laptop. Armed with 12 capacitors of 220μF on 50V of Sprague mark, of an RF filter, the voltage of 5V is thus freed from any parasitic noises.
Supplied with an external 5V USB type power supply, the result can be optimized even better with a linear or battery power supply.
Technical specifications:
  • Maximum Current: 5A.
  • Maximum Power: 25W.
  • Automatic power switching speed: <5ms.
  • Ripple factor: <1Hz.
  • Capacitors Sprague and Elna.
  • TDK armored inductors.
  • Relais Takamisawa Japanese.
  • Status LEDs.
the bundle contains:
  • Comes with two USB A to B USB3.0 cable.
  • Supplied with USB cable to Jack DC 1.3 and transformer 5 V 2A.
  • Dimensions: 120 x 74.5 x 24.4 mm.
  • Weight of the AXF 101 module: 186 g.
  • Weight of the complete package 660g.
Output voltage (V)5.0
Output current (A)5.0
Input voltage (V)5.0
2 reviews
JMC
Il est très facile à mettre en oeuvre. Il apporte une vraie amélioration à la qualité du son. Le son est plus précis avec des meilleurs timbres et est beaucoup plus aéré. Je peux gräce à lui écouter de la musique sur Deezer avec une qualité presque aussi bonne que sur ma platine cd Marantz et mon DP1 SMSL. Il ne supprime pas tout le souffle que peut générer mon pc portable sur ses ports USB mais il le diminue sévèrement et on fini par l'oublier.
This review has been posted for ElFIDELITY AXF-101 Ultra external USB 3.0 Booster Power Filter for PC
vraiment efficasse
Aussi bien en enregistrement qu'en écoute , ce petit redresseur fait des miracles
