A true 2-way quality filter with unique adjustment possibilities. Due to low cut-off frequencies around 2000 Hz, this filter can be used in particular with high-value 4 Ω high-pitch speakers. The 28 mm treble speakers are very well suited, for example the CARPOWER DT-284 "The Dome". Strong>
High Tech frequency filter for 4 Ω, 250 W systems MAX
Cut-off frequency approx. 2000 Hz, level adjustment of the treble speaker in 3 steps (-0 dB, -3 dB, -6 dB), phase inverter (0 ° / 180 °) for the loudspeaker d and other characteristics: slope switching between 6 and 12 dB / octave for both channels simultaneously. Designed with the best components, this high-quality filter is also part of the CARPOWER PRESET-1 system. As in the set, 4 Ω bass-speakers can be connected to the CDN-2X, but the filter also has an extra pair of terminals for a combination of a high-pitched loudspeaker 4 Ω with two 8 Ω bass-midrange speakers. The latter then automatically run in parallel in the filter. (Ideal 2 x PREDATOR-6/8).
Thethe power of the system, in particular the RMS power depends above all on the power of the loudspeakers used.
Span>
Specifications Speaker accessories Span> | |||
![]() | Cutoff frequency | ![]() | 2000 Hz Span> |
![]() | slope Span> | ![]() | 6 dB or 12 dB / oct. switchable Span> |
![]() | Output Impedance | ![]() | 4 Ω |
![]() | Input power max. | ![]() | 250 WMAX Span> |
![]() | Temperrature. Span> | ![]() | 0-40 ° C |
![]() | dimensions Span> | ![]() | 115 x 40 x 90 mm Span> |
