By buying this product you get 199 loyalty points
The CEN.GRAND 9I-806 is a headphone amplifier designed to drive high-end headphones. Four output types are available for headphone listening to accommodate the impedance level required for many models. This headphone amplifier delivers top-notch audio performance. Moreover, even if you input a single-ended signal, the internal circuitry will convert it to a balanced signal. So even if you input a single-ended signal, you'll still get the maximum output power.
Key points :
The four output modes will allow you to select the ones that best suit your listening preferences or the characteristics of your headphones. Normal mode is used for low impedance headphones and earphones and BTL mode for high impedance headphones. The Parallel mode is effective for medium impedance headphones, increasing the driving force but not the gain. Finally, the Active Ground mode provides a stronger sense of harmonics and is therefore suitable for listening to the human voice or string instruments. This last mode offers a softer and warmer listening experience.
1 | Headphones ouputs : 2x XLR 3 pins balanced / 2x Jack 6.35mm stereo single-ended |
2 | Headphone output Jack 4.4mm balanced |
3 | Screen |
4 | Input mode selection |
5 | Power on/off |
6 | Output mode selection |
7 | Headphone output XLR 4 pins balanced |
8 | Volume control |
9 | 2x Inputs RCA stereo single-ended |
10 | 2x Inputs XLR stereo balanced |
11 | Power input / Power switch on/off |
Product type | Headphone amplififer |
Inputs | 2* Balanced stereo XLR 2* Single-ended stereo RCA |
Outputs | 1* Balanced XLR 4-pin headphone output 1* Single-ended dual Jack 6.35mm headphone output (stereo) 1* Balanced Jack 4.4mm headphone output 1* Balanced dual XLR 3-pin headphone output |
Frequency response | 20-20 KHz (0.02%) |
Output power | 15W (30Ω BTL, distortion 0.02%) |
Supply voltage | AC 220-230V 50/60Hz |
Color | Silver |
Net weight | 6.9 kg |
Gross weight | 8.1kg |
Input | RCA |
Input | XLR |
Output | Jack 6.35mm |
Output | XLR |
Output | Jack 4.4mm |
Color | Silver |
Class | N/A |
Remote Control | N/A |
