SHANLING TEMPO eC1B CD Player and file reader on USB key Black
Shanling Tempo EC 1 CD Player port USB 16bit 44.1Khz
4.5 / 5
By buying this product you get 22 loyalty points
Reference : 11007
229,00 €tax incl.
190,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Shanling Tempo eC1B
CD Player and USB Flash Drive File Reader Black
Shanling Tempo eC1B Lecteur CD et de Fichiers sur Clé USB Argent
The Shanling Tempo eC1B CD player is based on a PCM1796 decoding chip and two NE5532P operational amplifiers, providing a rich musicality. The AOPs are mounted on a DIP8 bracket. The CD player features an extremely reliable Sanyo HD850 mechanism, ensuring flawless track tracking. The eCB1 Tempo also allows you to read dematerialized files stored on a USB stick or hard disk, thanks to its USB-A port on the front panel. It can also be used as a drive thanks to its Coaxial SPDIF output.
DiagramShanling Tempo eC1B Lecteur CD et de Fichiers sur Clé USB Argent
1Power ON/OFF LED
2Power ON/OFF button
3CD player tray
4Display
5IR receiver
6Multi-directionnal button
7USB-A Input
1Stereo RCA Output
2SPDIF Coaxial Output
3AC Power supply input
Product typeCD Player
Inputs1x CD
1x USB-A
Outputs1x Stereo RCA
1x Coaxial SPDIF
Conversion chipPCM1796
AOP2x NE5532P
CD MechanicSanyo HD850
Line output level2V
Dynamic range96dB
SNR105dB
THD< 0.002% (1kHz)
Crosstalk> 96dB
Supported dematerialized filesWAV, AAC, WMA, MP3
Sampling rate16bit 44kHz
Consumption< 20W
Dimensions216 x 312 x 71mm
Weight3kg
Power supply250V AC (cable included)
Package1x Shanling Tempo eCB1 Black
1x IR Remote control (CR2032 battery included)
1x Power cable
Channel2 (Stereo)
22 reviews
cpg
as one of the previous reviewers said, this is a very good transport. The only disadvantage is you cannot select the track number
This review has been posted for SHANLING TEMPO eC1B CD Player and file reader on USB key Black
EXCELLENT TRANSPORT CD
Voici deux ans que je vis avec ce petit Shanling Tempo et je souhaite apporter des précisions supplémentaires par rapport à l'avis que j'avais posté jadis. En effet on est toujours un peu trop pressé à donner un avis, alors que c'est seulement sur le long terme qu'on apprécie un objet technologique. Musicalement, ce Tempo CD est honnête et même très honnête compte tenu de son prix modeste. Disons qu'il rivalise avec des produits de marques Grand Public deux fois plus coûteux. Toutefois ce petit lecteur n'est pas parfait avec des limitations qui sont celles des appareils de milieu de gamme, disons jusqu'à 500 ou 600 euros. La définition est très bonne dans l'aigu et le médium mais un peu insuffisante dans le grave, légèrement "cotonneux". Du coup, l'image stéréo manque un peu de présence en profondeur, cela est surtout sensible sur la musique symphonique qui exige une localisation des instruments plus nette. En changeant les AOP d'origine (des Texas Instruments 5532) par de bons TLE 2142 CP le miracle ne s'est pas produit, ce qui prouve que les limitations viennent davantage de la puce de conversion que du préampli interne. Rien de trop grave cependant pour un DAC Bur Brown 1796 qui n'est plus une puce de dernière génération. En outre, ce lecteur privilégie la douceur, chose louable, mais ici un peu trop systématque ce qui gomme légèrement les aspérités de la musique, pourtant nécessaires. Malgré ses limites, je recommande chaudement le TEMPO CD en tant que transport CD, on bénéficiera ainsi d'une excellente mécanique Sanyo, précise, silencieuse et fiable, généralement montée sur des systèmes beaucoup plus coûteux. Ce TEMPO CD, accompagné d'un bon DAC externe risque bien d'accomplir des miracles. Le mien, couplé à un DAC à puce Asahi Kasei 4493, a transiguré la restitution sonore. Ces puces Asahi Kasei sont peu coûteuses et vraiment étonnantes ! La défintion est devenue excellente sur tout le spectre avec une transparence de haut niveau qui ordonne l'image stéréo en trois vraies dimensions. Les instruments du fond de l'orchestre sont parfaitement localisables et les atmosphères des lieux d'enregistrement très crédibles. La dynamique, libre, fait vivre la musique comme au concert. Et n'hésitez pas à vous munir d'un bon cable numérique coax comme le CANARE vendu sur ce site.
Excellent Lecteur CD
Rien à ajouter et aucun besoin de DAC en analogique.
Merci a l'équipe Audiophonic pour cet excellent emballage.
Impeccable
Petit lecteur cd très efficace, même non rodé les graves sont présents et bien charpentés, les médiums sonnent vrai, et l'aigu pas acide. C'est un beau début, je ferai un test avec un dac externe histoire de voir mais ca marche déjà très bien, dynamique et détaillé.
Very good cd transport
This is excellent as a cd transport! I find the onboard dac too soft with very diffuse instrument imaging within the soundstage. So I would not advise to use it that way. Use it as a cd transport only with a good external DAC (I use the Denafrips Ares 2) and it really shines ! It's very quiet, the opening and closing of the tray is smooth and quiet, no plastic rattling sounds as more expensive cd players sometimes have. Try finding another all alumium cd player for 200€ ! Most of them will have an ugly plastic front, this one is small but heavy and has a quality finish. Love the joystick, the fact that the lights can be totally dimmed from the remote....if you are lookin for a good cd transport, at 200€ this is an absolute steal and a no brainer really.
