The Silkline Tonemax T8 is an FM / DAB / DAB+ tuner equipped with an RDS decoder that allows you to broadcast analog FM radio as well as DAB+ digital radio, which is more recent and above all offers a much better quality of reproduction.
Simple, efficient and elegant, it will easily fit into your Hi-Fi installation. Moreover it has a station recording function allowing you to easily find up to 30 different bands whether in FM or DAB. It also has a screen displaying key information thanks to the RDS decoder (PTY, PS and text info) and a remote control.
It is equipped with a stereo RCA output as well as a Toslink optical output that you can pair with an external DAC. Reception for DAB reaches 384Kpbs which is much better than MP3 or CD audio quality standard.
Finally, its performance in terms of audio output sampling quality reaches PCM 48KHz thanks to its JRC5532 AOPs.
| Specifications | |
| Product type | Tuner FM / DAB / DAB+ |
| Reception type | DSP Digital high speed |
| Redio station memory | 30 FM stations 30 DAB stations |
| RDS decoder | (PTY, PS Text) |
| Inputs | 1* stereo RCA 1* Optical Toslink |
| Screen | OLED |
| Remote control | |
| Antenna | |
| FM reception frequency | 87.5MHz - 108MHz |
| DAB reception frequency | 174.5Mhz - 240MHz |
| Nominal output level | 500mV |
| Reception sensibility | FM: -106dB DAB: -99db |
| SNR | FM: 50dB DAB: 72dB |
| Wave distorsion | FM: <0,03% DAB: <0,03% |
| Channel separation | FM: 50dB DAB: 72dB |
| General | |
| Power supply | AC 220V |
| Dimensions | 430*200*44mm |
| Weight | 3kg |
| Package | 1x Silkline Tonemax T8 1x Remote control 1x Power cable 1x FM/DAB antenna |
| Input | DAB+ |
| Input | DAB |
| Input | FM |
| Output | RCA |
| Output | Optical Toslink |
| DAC / ADC Chip | NC |
| Max sampling rate | 48kHz |
| Color | Black |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
