ALLO NIRVANA Low noise audio power supply 5V 2.8A Black
This ultra low noise SMPS power supply offers a single power rail with a voltage of 5V and a maximum current of 2.85A.
Reference : 14576
65,90 €tax incl.
54,92 € tax excl.
Following a break in the black case, ALLO now offers its power supply in silver colour: ALLO NIRVANA Low noise audio power supply Silver.
Allo Nirvana
This ultra low noise SMPS power supply offers a single power supply rail with a voltage of 5V and a maximum current of 2.85A. It has two output connectors.
The first output is a DC jack connector located at the end of a cable (non-removable) and delivered with its full range of Jack DC / micro USB / USB-C adapters.
The second connector is on a female USB-A located directly on the front of the power supply.
The box has an earth connector and a switch on the front to activate / deactivate this connection.
The entire circuit is mounted in a 100% aluminum housing ideal for avoiding noise capture while providing excellent robustness to the device.
This power supply fits perfectly with the DAC REVOLUTION of the same brand, or any other device requiring 5V.
Audio Precision Measurements
Click on an image to enlarge the analysis result.
FFT 2A
FFT 2.8A
TypePower Supply
Power Supply technologySMPS 115-230V
Power Rail5V 2.85A
ConnectorsJack DC + adapters ( jack format+ micro USB / USB-C )
USB-A female
Cable lengthAC Cable : 1.30m
DC Cable : 1.5m
Plug TypeEU
InputSchuko
OutputUSB
OutputJack DC 5.5/2.5mm
Output voltage (V)5.0
Output current (A)2.8
Input voltage (V)220.0
Input voltage (V)100.0
Input voltage (V)120.0
Input voltage (V)130.0
Input voltage (V)115.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)110.0
Input voltage (V)230.0
Input voltage (V)200.0
Power SupplySMPS
5 reviews
Alimentation 5 Volts pour DAC externe
je recherchais une alim externe pour un DAC "usb", ayant d'abord utilisé une alim de base. David Aubert m'a encouragé à essayer cette alim à découpage et faible bruit ( pour son rapport qualité/ prix et sa compacité).Effectivement, c'est très satisfaisant et cela apporte un "plus" dans tous les domaines. cela peut être une alternative très valable à une alimentation linéaire. A Recommander pour un DAC USB
This review has been posted for ALLO NIRVANA Low noise audio power supply 5V 2.8A Black
Meilleur son
Super produit, boitier alu, port USB supplémentaire. Depuis qu'il est alimenté par cette alim, la Raspberry est content: plus de flash du led indiquant une trop faible tension, et j'ai vraiment le sentiment de l'entendre.
Il est plus "confortable" pour délivrer du son.
Merci !
Great Addon...
This power supply is of great workmanship. High quality components providing a fantastic sound to the ALLO Signature player. It is definitely worth upgrading to the Nirvana power supply, it lifted the connected device to another level of sound quality. Great advice by Audiophonics, their service is outstanding.
Excellent rapport Q/P
Alimentant un DAC SMSL, en comparaison d'une alimentation ifi iPower, la différence est "palpable". Plus dynamique et plus silencieuse surtout !
Disposer d'un second port en usb, même s'il est privé d'isolation galvanique, est très appréciable.
A ce prix, inutile de se creuser la tête en la comparant à des plus onéreuses, le bon choix est… ALLO
Very good quality, perfect linear power supply for high-end USB
I am happy to write a short review of this product. I use this linear power supply for high-end computer audio. It feeds an ifi defender. An ifi ilink USB is attached to it (USB-SPDIF converter). In my opinion, the USB-SPDIF converter benefits from this. The sound is excellent, which is certainly also due to the excellent converter.
The processing of the order and shipping to Germany worked perfectly. Audiophonics works very professionally with very good communication. The power supply arrived very quickly and excellently packaged.
Anytime again. Greetings to France.
Thank you for this great review.
A small correction : Allo Nirvana is a ultra low noise switching mode power supply (not a linear power supply).
