Avec l’alimentation AUDIOPHONICS LPSU25 branchée sur mon streamer Wiim Pro Plus, le bond en qualité sonore est immédiat. La musique gagne en impact, en précision et en naturel — chaque note est plus vivante, plus juste, plus intense
Low noise USB 5V 2A 25VA / 220V
Audiophile regulated power supply for any Hifi device running on 5V (DAC, digital sources for example).
Here is a regulated and stable linear power supply for any high quality DIY audiophile project. All the necessary technical refinements are incorporated into this dedicated audio power supply.
It includes a Hexfet IRF controller of series 34Z driven by low-noise OP Analog-Device and not an integrated circuit. The incorporated EMI RFI filtering ensures a very low noise (ripple) of electrical pollution (- of 30mv).
The components of this power supply are of first quality with DALE resistors and 4 capacitors of filtering BC of 220μf each. A fuse F0.25A 250V ensures the protection of the device. The benefits of a linear quality feed are better readability of the acute medium and a much better cut out.
This regulated linear power solution developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two DC 5.5 / 2.1mm output jacks, this power supply with an extremely stable 25VA transformer even under heavy load will allow you to make the best of audio connected.
As this power supply do not have over current protection, the load should not exceed it's capacity.
For use with a RaspTouch: If a yellow flash appears on the screen, you can adjust the output voltage of the power supply using the screw on the back of the unit until the flash disappears.
AC Power cable sold separately.
Input voltage | AC 220V |
Output Voltage / current | 5V 2.0A MAX Continuous 5V 3.5A DC (5 min) |
Outputs | Jack DC 5.5/2.1mm 2x USB-A 5V |
Input | IEC |
Vibration-proof molded transformer 25VA shielded | - |
Internal fuse | 0.5A Fast |
Case material | 100% Brushed & Sandblasted Aluminium |
Anodising | Yes |
Dimensions | 174 x 100 x 51mm |
Weight | 0.85kg |
DC 5.5/2.1 jack cord and mains cable not included.
Presentation of the linear power supply regulated by
The Hans Beekhuyzen Channel
We recommend for the ALLO DIGIONE this
Power supply
Input | IEC C14 |
Output | Jack DC 5.5/2.1mm |
Color | Black |
Output voltage (V) | 5.0 |
Output current (A) | 2.0 |
Input voltage (V) | 230.0 |
Power Supply | Linear |
Average votes 4.9 / 5 54 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Paul A.
Paul A.
Gaetan M.
Loic T.
Jean-Marc M.
