AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 115V to 12V 1.25A 25VA
15%
This is a stable, regulated linear power supply for any high-quality DIY audiophile project.
Reduced price!
Reference : 16953
Limited time offer:
75,00 €tax incl.
-15%
63,75 €tax incl.
53,13 € tax excl.
Shipping date: 01-05-2026.
Linear Power Supply
Low noise 12V 1.25A 25VA / 115V
audiophonics almentation linéaire régulée
Power supply for special 110/115V networks!
European friends, do not use this power supply! Instead, go to the 220V version !
Audiophile regulated power supply for any Hifi device running on 12V DC (DAC, digital sources for example).
Here is a regulated and stable linear power supply for any high quality DIY audiophile project. All the necessary technical refinements are incorporated into this dedicated audio power supply.
It includes a Hexfet IRF controller of series 34Z driven by low-noise OP Analog-Device and not an integrated circuit. The incorporated EMI RFI filtering ensures a very low noise (ripple) of electrical pollution (- of 30mv).
The components of this power supply are of first quality with DALE resistors and 4 capacitors of filtering BC of 220μf each. The benefits of a linear quality feed are better readability of the acute medium and a much better cut out.
This regulated linear power solution developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two DC 5.5 / 2.1mm output jacks, this power supply with an extremely stable 25VA transformer even under heavy load will allow you to make the best of audio connected.
As this power supply do not have over current protection, the load should not exceed it's capacity.
Input voltageAC 115V
Output Voltage / current12V 1.25A MAX Continuous
12V 2A  MAX (5min)
OutputsJack DC 5.5/2.1mm
2x USB-A 5V
InputIEC
Vibration-proof molded transformer 25VA shielded-
Case material100% Brushed & Sandblasted Aluminium
AnodisingYes
Dimensions174 x 100 x 51mm
Weight0.85kg
DC 5.5/2.1 jack cord and mains cable not included.
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)12.0
Output current (A)1.25
Input voltage (V)115.0
Power SupplyLinear
