LHY-AUDIO LPS-80 Low Noise Linear Regulated Power Supply
The LHY-Audio linear power supply is a low-noise power supply based on the use of a high quality custom toroidal transformer, high-performance LT3086 regulators, high-current, low-resistance Schottky rectifiers, and Vishay BC electrolytic capacitors, all mounted on a four-layer PCB with gold-plated copper circuits.
Reference : 21576
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 19-11-2026.
LHY-Audio LPS-80 Low-Noise Regulated Linear Power Supply 220-240V to 12V DC 2A + 19V DC 3A
LHY-AUDIO LPS-80
The LHY-Audio linear power supply is a low-noise power supply based on the use of a high quality custom toroidal transformer, high-performance LT3086 regulators, high-current, low-resistance Schottky rectifiers, and Vishay BC electrolytic capacitors, all mounted on a four-layer PCB with gold-plated copper circuits. This power supply is capable of delivering 12V DC 2A and 19V DC 3A simultaneously and without interference, allowing it to power multiple HiFi devices. The output is protected against short circuits and overcurrent.
Components of the LHY-AUDIO LPS-80 power supply
Overview of the LHY-AUDIO LPS-80 Power Supply
Overview of the LHY-AUDIO LPS-80 power supply
1Power button
2Display
3DC outputs on GX16 connectors
4220-240V AC mains input
Technical Specifications
Product typePower supply
Output voltages1x 12V DC 2A
1x 19V DC 3A
Outputs2x GX16 2-pin connectors
Regulation circuit4x LT3086 (80W)
Output voltage accuracy±2 %
Load regulation±2 %
No-load noise< 50 μV
Noise under load< 50 μV
Power supply rejection ratio (PSRR)80dB (120Hz)
Overcurrent protection105% to 130%
Power supply220-240V AC 50/60Hz
Dimensions250 x 130 x 60mm
Weight2.1kg
Package contents1x LHY-Audio LPS-80
1x OFC Copper GX16 to DC jack 5.5/2.1 power cable
1x OFC Copper GX16 to DC jack 5.5/2.5 power cable
1x AC power cable
InputIEC C14
OutputGX16
Output voltage (V)19.0
Output voltage (V)12.0
Output current (A)2.0
Output current (A)3.0
Input voltage (V)240.0
Input voltage (V)220.0
Power SupplyRegulated Linear Power Supply
LHY-AUDIO LPS-80 Low Noise Linear Regulated Power Supply 12V DC 2A + 19V DC 3A
The LHY-Audio linear power supply is a low-noise power supply based on the use of a high quality custom toroidal transformer, high-performance...
