Nice quality build PSU with good connectors. Packed nicely and shipped fast!
100-240V AC vers 48V 7A DC
This AC adapter takes an input voltage of 100-240VAC to output 48VDC 7.3A (350W). The components are integrated in a robust aluminum chassis that dissipates the heat generated by the components. The power supply ensures a very low ripple to provide a clean electrical signal to your HiFi devices. The circuit also integrates protections against overcurrents, overvoltages, thermal overshoot and short circuits. The AC input is on an IEC C14 connector and the output on a GX16 connector.
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain devices. Using a non-compatible cable can result in the destruction of your equipment.
The cable to be used with this power supply must have the following polarity. Check that it is compatible with your equipment before use:
Product type | Switched mode power supply |
Input | 1x IEC C14 |
Output | 1x GX16 |
Input voltage | 100-240VAC 50/60Hz |
Output voltage | 48VDC 7.3A |
Voltage precision | ±5% |
Package | 1x Switched mode power supply 1x Power cable 1x GX16 to Jack DC 5.5/2.5mm (5.5/2.1mm compatible) cable |
Dimensions | 102 x 208 x 50mm |
Housing material | Brushed aluminium Black front panel |
Input | IEC C14 |
Output | GX12 |
Color | Silver |
Color | Black |
Output voltage (V) | 48.0 |
Output current (A) | 7.0 |
Input voltage (V) | 200.0 |
Input voltage (V) | 220.0 |
Input voltage (V) | 100.0 |
Input voltage (V) | 130.0 |
Input voltage (V) | 230.0 |
Input voltage (V) | 210.0 |
Input voltage (V) | 240.0 |
Input voltage (V) | 110.0 |
Input voltage (V) | 120.0 |
Power Supply | SMPS |
Average votes 4.8 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Anastasios D.
Patrick D.
Simon V.
Rodolphe G.
