Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Button type
Number of positions
Roland S.
Dac tv
Walter V.
Great product!
Joli mais non..
IEC Inlets
Discover our range of IEC plugs of all sizes, for the integration of a power connector on your HiFi devices.
