DUNU CONCEPT R CD Player
The DUNU Concept R is a portable CD player that combines retro-futuristic design with state-of-the-art audiophile performance. Featuring a fully discrete R-2R DAC architecture and amplification selectable in Class A or AB modes, it offers an authentic analog listening experience, whether on the move or at home.
By buying this product you get 85 loyalty points
Reference : 20766
859,00 €tax incl.
715,83 € tax excl.
Shipping date: 12-11-2026.
Dunu Concept R CD Player DAC R2R 32bit 768kHz DSD512
Dunu Concept R photo
This makes the DUNU Concept R the ideal companion for audiophiles wishing to rediscover their CD collections with exceptional sound quality, combining modern technology with retro charm.
Dunu Concept R: High-end design
At the heart of the Concept R is a discrete, symmetrical four-channel R-2R DAC, featuring 192 precisely matched resistors. This configuration ensures smooth, natural digital-to-analog conversion, reproducing musical detail with exceptional fidelity. The integrated amplifier offers output power of up to 1.3W into 32Ω in balanced mode, with the option of choosing between Class A and AB modes to tailor the sound signature to the user's preferences.
Dunu Concept R: Elegant design and intuitive functions
The Concept R is machined from a block of aerospace-grade aluminum, offering a robust structure and refined aesthetics. Its user interface features a 2.08” monochrome OLED display and a digital volume slider inspired by analog controls, facilitating intuitive navigation. The CD playback mechanism features a high-performance servo developed in-house, guaranteeing precise playback of 12cm and 8cm CDs, including CD-Rs.
Dunu Concept R: Connectivity and autonomy
The Concept R offers versatile connectivity with unbalanced Jack 6.35mm and balanced Jack 4.4mm headphone outputs, a balanced Jack 4.4mm line output for external amplifiers, as well as an optical output and USB audio input supporting PCM up to 32bit 768kHz and DSD up to DSD512. It's powered by a 12000mAh (31.58Wh) battery, offering extended autonomy for long listening sessions.
Product typeCD player
InputsCD player
Bluetooth 5.3
Outputs1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 4.4mm headphone output
1x Coaxial
1x Optical Toslink
Decoding architectureDiscrete R-2R DAC with four-channel symmetrical architecture
CD compatibility12cm & 8cm CD / CD-R
Supported Bluetooth codecsSBC, aptX, aptX Adaptive
Battery capacity3.8V 12000mAh (31.58Wh)
Battery lifetime10h of playback
Amplification typeClass A / AB
Jack 3.5mm output power (transistors)Low gain: 57mW @ 32Ω
High gain: 158mW @ 32Ω
High gain: 330mW @ 32Ω (DC supply)
Jack 3.5mm output power (tubes)Low gain: 47mW @ 32Ω
High gain: 268mW @ 32Ω (DC supply)
Jack 4.4mm output power (transistors)Gain faible : 195mW @ 32Ω
Gain élevé : 551mW @ 32Ω
Gain élevé : 1220mW @ 32Ω (alimentation DC)
Jack 4.4mm output power (tubes)Gain faible : 195mW @ 32Ω
Gain élevé : 1087mW @ 32Ω (alimentation DC)
Supported sampling rates (USB DAC)PCM up to 32bit 768kHZ
DSD up to DSD512
THD+NJack 3.5mm output: 0.03%
Jack 4.4mm output: 0.02%
Dynamic rangeJack 3.5mm output: 116dB
Jack 4.4mm output: 117dB
SNRJack 3.5mm output: 116dB
Output impedanceJack 3.5mm output: 4.7Ω
Jack 4.4mm output: 6.6Ω
ScreenOLED 2.08"
Supply voltage5V 2A or 9V 2A via USB-C
Weight~ 1.16kg
Dimensions205 x 150 x 32mm
ColorSilver
Package1x Dunu Concept R
1x USB-C charging cable
1x Protective case
DUNU CONCEPT R CD Player R2R DAC 32bit 768kHz DSD512
The DUNU Concept R is a portable CD player that combines retro-futuristic design with state-of-the-art audiophile performance. Featuring a fully...
