DUNU V53 Balanced Headphone Amplfiier
The Dunu V53 is a balanced desktop headphone amplifier combining refined design and exceptional audio performance. The result of a collaboration between Dunu and NiuNiu Audio, this amplifier is designed to deliver an immersive and faithful listening experience, meeting the expectations of the most demanding audiophiles. The V53 boasts first-rate technical specifications, guaranteeing precise sound reproduction with minimal distortion and wide dynamic range, so you can get the most out of your audiophile headphones.
By buying this product you get 169 loyalty points
Reference : 20707
1 699,00 €tax incl.
1 415,83 € tax excl.
Dunu V53 Balanced headphone amplifier
Dunu V53 photo
Key features:
  • Battery-powered headphone amplifier.
  • High-quality internal components.
  • Neotech Silver OCC 7N internal cable.
  • Elegant, modern design.
  • Extended autonomy.
Dunu V53: Balanced amplifier circuit
The Dunu V53 benefits from a fully balanced four-channel amplifier circuit using Texas Instruments high-end OPAs. This high-performance amplification stage develops a significant 1200mW of power at 64Ω (on battery and balanced output) while maintaining an extremely low THD+N. This comfortable power allows the V53 to easily accompany demanding high-impedance headphones.
Dunu V53: Elegant design and robust construction
With dimensions of 344.5 x 237 x 68.5mm and a weight of around 3.93kg, the V53 features a brushed aluminum chassis, machined from a single block of 6063 aluminum, combining modern aesthetics with robustness. Its sleek design blends harmoniously into any audiophile or professional environment.
Dunu V53: Autonomy and power supply
The V53 is equipped with a 88Wh battery, made up of six Sanyo NCR1850 cells, offering a runtime of around 24 hours, allowing extended use without the need for frequent recharging. It comes with a DC power adapter, with LED indicators: red for charging in progress and green when the battery is fully charged.
What's more, battery operation ensures a perfectly clean, interference-free power supply for excellent sound quality.
Dunu V53: High-end components
The Dunu V53 uses high-quality components to deliver incredible audio performance. These include Nichicon KZ and ELNA Silmic2 capacitors, Panasonic relays and Neotech silver 7N OCC internal wiring.
Teechnical characteristics
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Balanced Jack 4.4mm headphone output
1x Balanced XLR 4 pins headphone output
1x Single-ended Jack 6.35mm headphone output
1x Jack 4.4mm line output
Output impedanceSingle-ended output: 1Ω
Balanced output: 1Ω
SNR> 132dB (A-weighted)
Dynamic range> 132dB (A-weighted)
Crosstalk< -115dB @ 1kHz
GainLow: +4.8dB
High: +12.5dB
THD+N0.0005% @ 30Ω
0.0004% @ 300Ω
Battery capacity88Wh
Battery lifetime24h
Supply voltage30V DC 0.5A on LEMO 2 pins connector (polarity: red dot = positive +30V)
Weight~ 3.93kg
Dimensions344.5 x 237 x 68.5mm
ColorSilver and black
Package1x Dunu V53
1x Power adapter
InputXLR
OutputJack 4.4mm
OutputJack 6.35mm
ColorSilver
ClassN/A
DUNU V53 Balanced Headphone Amplifier
The Dunu V53 is a balanced desktop headphone amplifier combining refined design and exceptional audio performance. The result of a collaboration...
