7HZ G1 In-Ear Monitors
The G1 from 7Hz are low-cost in-ear headphones featuring a Ø10mm driver with a DLC (Diamond-like carbon) membrane. Its dual magnetic circuit, coupled with its dual acoustic cavity, enables the brand to offer a sound experience that is as close as possible to Harman's curve, offering a transparent sound experience with a natural timbre.
Reference : 20577
39,90 €tax incl.
33,25 € tax excl.
7Hz G1 Dynamic In-Ear Monitors IEM 18 Ohm 107dB 10Hz-20kHz
7HZ G1 : Front view
7Hz G1 : 10mm dynamic driver
The 7Hz G1 earphones feature a dynamic driver with a DLC (Diamond-like carbon) membrane. The rigidity of this type of carbon gives excellent transient response and high-frequency extension. Furthermore, this driver is equipped with a double acoustic cavity for improved filtering of standing waves and finer control of frequency response. Finally, the driver is equipped with a dual N52 magnetic circuit, improving the sensitivity of the earphones.
7HZ G1 : earphone on a book
7HZ G1 : Cable on a book
7Hz G1 : Cable and microphone
The G1 comes with a 3.5mm jack to 0.78mm 2-pin OFC copper cable, ensuring optimum signal transmission so you can enjoy the full performance of the earphones. Furthermore, the cable includes a microphone, so you can make phone calls without taking your earphones out of your ears.
Product typeIn-ear monitors (IEM)
Driver1x Ø10mm dynamic driver
Frequency response5Hz - 20kHz
Impedance18Ω
Total harmonic distortion (THD)< 0.5% @ 1KHz
Sensitivity107dB
Earphone connectorsCIEM 0.78mm 2 pins
Cable materialsOFC Copper
Cable terminationJack 3.5mm
Package1x 7Hz G1
1x Jack 3.5mm to CIEM 0.78mm 2 pin cable with microphone
1x Carrying bag
5x Pairs of ear tips
Impedance (Ω)18
Efficiency / Sensitivity (dB)107
WirelessNo
Phone call featureYes
Noise reductionNo
7HZ G1 Dynamic In-Ear Monitors IEM 18 Ohm 107dB 10Hz-20kHz
The G1 from 7Hz are low-cost in-ear headphones featuring a Ø10mm driver with a DLC (Diamond-like carbon) membrane. Its dual magnetic...
