7HZ X CRINACLE SALNOTES DIOKO In-Ear Monitors
With the Salnotes Dioko, 7HZ has teamed up with Crinacle, renowned for its expertise in IEM, to offer in-ear monitors based on a Ø14.6mm planar magnetic driver and accompanied by a host of technologies to deliver a natural sound experience with transparent timbre and remarkable definition.
Reference : 20586
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 24-06-2025.
7HZ x Crinacle Salnotes Dioko In-Ear Monitors IEM Planar Magnetic Ø14.6mm 16 Ohm 106dB 5Hz-40kHz
7HZ x Crinacle Salnotes Dioko : Front view
7Hz Salnotes Dioko: Ø14.6mm magnetic planar driver
The Salnotes Dioko feature a planar magnetic driver with a double acoustic cavity and a Ø14.6mm diaphragm. This is optimised to make the most of the ribbon distribution used on the diaphragm, improving phase coherence and giving a more linear frequency response. Furthermore, its large size increases the surface area of vibration, reducing harmonic distortion and resulting in a soundstage with improved resolution.
7HZ x Crinacle Salnotes Dioko : earphones on a smartphone
7Hz Salnotes Dioko: Frequency response
To perfect the settings of the chosen driver, 7Hz teamed up with the renowned audio critic Crinacle. The combined experience of the brand and Crinacle resulted in a balanced frequency response, the fruit of an integrative tuning strategy.
7HZ x Crinacle Salnotes Dioko : Frequency response
Thanks to structural adjustment techniques, the bass of the Salnotes Dioko is punchy, while retaining a neutral midrange for a precision comparable to that of monitoring headphones. The treble of the Salnotes Dioko is natural, but makes full use of the characteristics of the planar magnetic driver, namely perfect presentation of detail and great transparency. The calibration of the Salnotes Dioko is inspired by Crinacle's own definition of what natural, balanced earphones should be, adapted for professional use.
7HZ x Crinacle Salnotes Dioko : Double magnet N55
7Hz Salnotes Dioko: Dual N55 configuration
The Salnotes Dioko planar magnetic driver features a dual N55 magnet structure, positioned on either side of the diaphragm. These extremely powerful magnets, combined with the structure of the magnetic circuit, maximise the effective magnetic flux to drive the current more effectively, resulting in increased sensitivity.
7Hz Salnotes Dioko: Sophisticated aesthetics
Featuring a high-quality CNC-machined aluminium body, the earphones are durable and lightweight, perfect for everyday wear. The solid metal casing provides sound insulation, so you can concentrate on your music. Furthermore, the surface of the shell has undergone a very high level of hard oxidation treatment, making the surface durable and resistant to abrasion.
For a luxurious finish, the Salnotes Dioko have a tempered glass back with a sapphire coating and an anti-scratch coating.
7HZ x Crinacle Salnotes Dioko : Rear view
7HZ x Crinacle Salnotes Dioko : earphones with cable
7Hz Salnotes Dioko: Silver-plated OCC copper cable
The Salnotes Dioko come with a detachable cable made from a mix of OCC copper and silver-plated OCC copper. With a total of 216 strands interwoven in litz wire, this cable ensures optimum signal transmission, allowing you to take full advantage of the performance of your earphones.
Product typeIn-ear monitors
Haut-parleurØ14.6mm planar magnetic driver
Frequency response5Hz - 40kHz
Impedance16Ω
Total harmonic distotion (THD)≤ 0.2% @ 1khz
Sensitivity106dB/v @1kHz
Earphone connectorsCIEM 0.78mm 2 pins
Cable conductor materialOCC Copper
Cable terminationJack 3.5mm
ColorPurple
Package1x 7Hz Salnotes Dioko
1x 3.5mm jack to CIEM cable
1x Carrying bag
6x Pairs of ear tips
ColorViolet
Impedance (Ω)16
Efficiency / Sensitivity (dB)106.0
WirelessNo
Phone call featureNo
Noise reductionNo
7HZ X CRINACLE SALNOTES DIOKO In-Ear Monitors IEM Planar Magnetic Ø14.6mm 16 Ohm 106dB 5Hz-40kHz
With the Salnotes Dioko, 7HZ has teamed up with Crinacle, renowned for its expertise in IEM, to offer in-ear monitors based on a Ø14.6mm...
