CRINEAR DAYBREAK In-Ear Monitors
With Daybreak, CrinEar presents a pair of in-ear earphones combining five drivers per side in a hybrid configuration that brings out the best in each technology. Designed to offer neutral sound reproduction with pleasant listening, they combine advanced crossover design with rigorous tuning methodology and optimised wearing comfort. The result is earphones tailored for long listening sessions, minimising both auditory and physical fatigue.
Reference : 20979
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 07-04-2026.
CrinEar Daybreak In-Ear Monitors IEM Dynamic Balanced Armature Planar Magnetic 20 Ohm 105dB 2Hz-40kHz
CrinEar Daybreak : Front view
With Daybreak, CrinEar presents a pair of in-ear monitors combining five drivers per side in a hybrid configuration that brings out the best in each technology. Designed to offer neutral sound reproduction with pleasant listening, they combine advanced crossover design with rigorous tuning methodology and optimised wearing comfort. The result is earphones tailored for long listening sessions, minimising both auditory and physical fatigue.
CrinEar Daybreak: Hybrid 5-driver design
The Crinear Daybreak features five drivers per earphone, utilising different technologies to ensure optimal coverage across the entire audio spectrum. A 10mm dynamic driver handles the bass, with extended and controlled response. Two balanced armature transducers ensure accurate and detailed midrange reproduction. Finally, two latest-generation planar magnetic tweeters handle the high frequencies with excellent extension.
CrinEar Daybreak : connected earphone
CrinEar Daybreak: IEF Preference 2025 curve as a guideline
The acoustic development of the Daybreak was based on the renowned Brüel & Kjær Type 5128 simulator, ensuring extreme precision in reproducing the target curve.
CrinEar Daybreak : frequency response curve and target curve
The tuning has been meticulously calibrated to align as closely as possible with the IEF Preference 2025 curve, renowned for offering a natural, balanced and pleasant sound during long listening sessions. The result is a neutral sound with a slight warmth in the bass, very neutral midrange and detailed but never harsh treble.
CrinEar Daybreak : 3D-printed resin body
CrinEar Daybreak: 3D printing and custom crossover
The Daybreak enclosure is made from 3D-printed acrylic resin, a method that allows for extreme precision in shaping the internal acoustic channels. Thanks to this technology, Crinear has been able to develop a complex crossover that is perfectly suited to the characteristics of each driver. This approach ensures optimal frequency distribution, a smooth transition between each band and tonal consistency rarely achieved in this price range.
CrinEar Daybreak: Wearing comfort
The ergonomics of the Daybreak earphones have been given special attention: their contoured shape naturally fits the ear for a secure fit without uncomfortable pressure points. The acoustic nozzle, with a diameter of less than 6 mm, offers an excellent compromise between durability, isolation and comfort, ensuring a comfortable fit even during long listening sessions.
CrinEar Daybreak : earphone in the Brüel & Kjær Type 5128 simulator
CrinEar Daybreak : 3.5mm and 4.4mm jack connectors
CrinEar Daybreak: Detachable cable with interchangeable termination
The Daybreak comes with a detachable silver-plated copper cable, ensuring optimal conductivity for lossless signal transfer. It features interchangeable terminations, allowing you to easily switch between a single-ended 3.5mm jack output and a balanced 4.4mm jack output, depending on your devices and preferences.
Product typeIn-ear monitors (IEM)
Driver type1x Dynamic driver
2x Balanced armature drivers
2x Planar magnetic drivers
Impedance20Ω
Sensitivity105dB
Frequency response2Hz - 40kHz
Earphone connectorsCIEM 0.78mm 2 pins
Cable conductorsSilver-plated copper
Cable shieldingJack 3.5mm
Jack 4.4mm
Conditionnement1x CrinEar Daybreak
1x Earphone cable 1.2m
1x 3.5mm jack termination
1x 4.4mm jack termination
1x Leatherette carrying case
4x Pairs of eartips
Impedance (Ω)20
Efficiency / Sensitivity (dB)105.0
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
Phénoménal !
J'ais demandé conseil à l'équipe d'audiophonics pour une écouteur ayant comme critère de bon timbre.
Àu départ j'été impressionner par ces timbres réaliste .
Mais j'était déçu par sa sonorité froide , clinique , pas de basse , manquant d'ampleur , de chaleur et se se sentiment enveloppent .
Avec le DC07pro , rien a faire , c'est trop analytique , cela semble être une association pour l'analyse , sans vie , avec un cayin Ru6 , cela semble s'améliorer mais manque toujours des basse , mais apporte une certaine chaleur , malheureusement c'est une association movaise pour les autre fréquences .
Vien a le brancher sur un E1DA 9039s . Woaouuu !!!
La gifle ! Les basse sont apparue , le son est enveloppant , sa claque , les grosse caisse frape fort et nette , dynamique , les reste des fréquence s'affiche clairement ... Tout est magnifique .
C'est comme un ampli de classe A de bureau mais d'une grande propreté . Un truc haut de gamme ce 9039s .
Utilisation sur android via UAPP + Qobuz .
J'ais une certaine expérience dans la hi-fi ayant essayé de nombreuses associations : Buchard , sonus faber , rotel , cambridge , BW , Nuprime , Focal et plein d'autre depuis plusieurs anné ...
Tout cela pour vous dire que vous avez la un quite qui vous coûtera trés peut , mais d'une autre musiqualité et performance .
Je conseille donc cette association . 9039s + Daybreak .
Ps : on entend dire que le nouveaux lot comprend les embouts " coffé " .
Faux ! J'ais commander les embouts coffé ( KBEAR ) et elle ont un alésage différant . Et le rendu est moin bon que celui fournie par Crinear . Ceux fournie par le fabriquant ressemble de très prêt au coffe , mais on plus de présence en lbasse. ( Pour mon oreil ) .
Le casque est à son plein potentiel après une 30 ene d'heures d'utilisation. Soyer patient , puisque les basse prennent du temp à se lâcher , ( même chose qu'avec les Focal élégia ) .
Merci à audiophonics et à YHWH d'avoir conçu nos oreils aussi merveilleusement !
This review has been posted for CRINEAR DAYBREAK In-Ear Monitors IEM Dynamic Balanced Armature Planar Magnetic 20 Ohm 105dB 2Hz-40kHz
With Daybreak, CrinEar presents a pair of in-ear earphones combining five drivers per side in a hybrid configuration that brings out the best in...
