DDHIFI X MOONDROP SURFACE In-Ear Monitors
The result of a collaboration between ddHiFi and Moondrop, Surface in-ear monitors feature a sophisticated five-driver hybrid system for extended, balanced frequency-band coverage. This configuration combines four Balanced Armature (BA) drivers and one Dynamic Driver (DD), orchestrated by Moondrop's expertise in crossover design, to deliver a natural soundstage with powerful, present low-mids.
By buying this product you get 27 loyalty points
Reference : 20684
279,00 €tax incl.
232,50 € tax excl.
Shipping date: 02-07-2025.
ddHiFi x Moondrop Surface In-Ear Monitors IEM Dynamic Balanced Armature 15 Ohm 118dB 10Hz-30kHz
ddHiFi Surface : Front view
ddHiFi Surface: Five-speaker hybrid architecture for complete sound reproduction
The Surface exploits the synergy of five drivers: a dynamic driver dedicated to deep, punchy bass, and four Balanced Armature drivers distributed for precise, detailed midrange and treble reproduction. By assigning complementary frequency bands to each type of driver, thanks to Moondrop optimization, these headphones deliver a natural sound, rich in detail and particularly expressive in the lower midrange.
ddHiFi Surface : internal composition
ddHiFi Surface: A double crossover developed in collaboration with Moondrop for optimum sound coherence
ddHiFi, in partnership with Moondrop, has designed an innovative double crossover system for Surface, exploiting both the earphones' printed circuit board and the design of their acoustic chambers. The printed circuit ensures precise filtering, guaranteeing that each driver operates in its optimum frequency range. At the same time, the acoustic chamber, meticulously developed and 3D-printed, acts as a physical filter, enabling harmonious fusion of the different drivers for a coherent, immersive final sound result.
ddHiFi Surface : PCB
ddHiFi Surface : cable
ddHiFi Surface: BC120S silver-plated OFC copper cable for lossless signal transmission
Surface in-ear monitors come with ddHiFi's BC120S cable, a high-quality, silver-plated OFC copper cable. Its core uses a Litz wire structure consisting of 30 strands of 0.10mm diameter, combined with a Litz wire shield of 116 strands of 0.05mm. Equipped with a 4.4mm jack termination, this cable ensures unaltered audio signal transmission, fully enhancing the exceptional performance of Surface headphones.
ddHiFi Surface: Frequency response
ddHiFi Surface : Frequency response
Product typeIn-ear monitors
Drivers1x Dynamic driver
4x Balanced armature driver
Frequency response10Hz - 30kHz
Impedance15Ω
Sensitivity118dB/Vrms @ 1kHz
Total harmonic distortion (THD)≤ 1% @ 1kHz
In-ear monitors connectorsCIEM 0.78mm 2 pins
Cable conductor materialSilver-plated copper
Cable terminationJack 4.4mm
ColorSilver
Package1x ddHiFi Surface
1x ddHiFi BC120S cable
1x Carrying case
3x Pairs of ear tips
ColorSilver
Impedance (Ω)15
Efficiency / Sensitivity (dB)118.0
WirelessNo
Phone call featureNo
Noise reductionNo
DDHIFI X MOONDROP SURFACE In-Ear Monitors IEM Dynamic Balanced Armature 15 Ohm 118dB 10Hz-30kHz
The result of a collaboration between ddHiFi and Moondrop, Surface in-ear monitors feature a sophisticated five-driver hybrid system for extended,...
