By buying this product you get 57 loyalty points
The Dunu SA6 MK2 are in-ear earphones featuring a total of six balanced armature drivers combined with a crossover system that combines physical and electronic solutions for a sound that is both smooth and detailed. Their aesthetics, a combination of wood, gold particles and resin, give each piece a unique design for a look that is both understated and distinguished.
The SA6 MK2 adopts an architecture based entirely on balanced armature drivers specially configured to ensure consistent reproduction across the entire audible spectrum. In the bass range, two custom transducers are dedicated to low frequencies. They are combined with an airflow control valve, which regulates the internal pressure of the cavity. This combination improves impact and depth while avoiding excessive compression, ensuring powerful, fast and well-defined bass.
The midrange is handled by two Knowles balanced armature drivers, optimised for mid and mid-high frequencies. Their linear response and low distortion ensure detailed and natural sound reproduction. This configuration provides a smooth transition between dynamic bass and clear treble.
Finally, two additional Knowles balanced armature drivers are dedicated to high frequencies. Designed to work in the treble range, they deliver accurate reproduction with good extension and an airy timbre.
Equipped with a three-channel independent sound wave guidance system and an electronic frequency division controller, the SA6 MK2 features a dual-channel physical and electronic frequency division system that delivers a controlled frequency response with rare precision. This system coordinates the six balanced armature drivers to deliver smooth, natural sound with a wide soundstage and excellent clarity.
Dunu has equipped the SA6 MK2 with a switch that offers users two different sound signatures. The standard setting (‘1’) provides a precise and balanced response, while the alternative setting (‘ON’) offers greater presence in the low frequencies for a warmer and more dynamic sound.
The Dunu SA6 MK2 are made with exceptional craftsmanship. Their shells are entirely handmade and feature specially selected stabilised solid wood panels. Each panel has similar colours but different textures, making each piece unique. They are coated with a resin mixed with gold powder that flows through the pattern to create a result of rare elegance.
The same level of attention has been paid to wearing comfort as to sound reproduction. The SA6 MK2 features an optimised and improved shape thanks to a new ear cup design. The result is a more rounded shape for optimal wearing comfort.
The SA6 MK2 comes with a detachable silver-plated copper cable, ensuring optimal conductivity for lossless signal transfer. It is equipped with interchangeable terminations, allowing you to easily switch between a single-ended 3.5mm jack output and a balanced 4.4mm jack output, depending on your devices and preferences.
Product type | In-ear monitors |
Drivers | 6x Balanced Armature drivers |
Frequency response | 5Hz-40kHz |
Impedance | 24Ω |
Sensitivity | 114dB |
Total harmonic distortion (THD) | 0.5% @ 1kHz |
Earphone connectors | CIEM 0.78mm 2 pins |
Cable terminations provided | Jack 3.5mm Jack 4.4mm |
Cable length | 1.2m |
Color | Wood |
Package | 1x Dunu SA6 MK2 1x Earphone cable 1x 3.5mm jack termination 1x 4.4 mm termination 1x Carrying case 1x 3.5mm to 6.35mm jack adapter 11x Pairs of ear tips |
Color | Wood |
Impedance (Ω) | 24 |
Efficiency / Sensitivity (dB) | 114.0 |
Wireless | No |
Cable termination | Jack 4.4mm |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
